ADV7619 video clamping
Question asked by ak1000 on Aug 14, 2014
Latest reply on Aug 20, 2014 by GuenterL
Trying to initialize the ADV7619 for 1920x1080 (see below) but the video is being clamped 16-235
What is clamping in the ADV7619? Also when I use the script for UHD (3840x2160@30Hz) I do not see the clamping for this resolution.
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
68 C0 03 ; ADI Recommended Write
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 12 ; force RGB 0-255, RGB out, op_656 bit = 0
98 03 40 ; 24 bit SDR 444 Mode 0
98 05 28 ; AV Codes Off #
98 06 A0 ; No inversion on VS,HS pins
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL MUX enable
44 BA 01 ; Set HDMI FreeRun
44 6C 00 ; Required ADI write –this fix it in the ADV7611
64 40 81 ; Disable HDCP 1.1 features
4C B5 01 ; Setting MCLK to 256Fs
68 C0 03 ; ADI Required write
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; ALL BG Ports enabled
68 03 98 ; ADI Required Write
68 10 A5 ; ADI Required Write
68 45 04 ; ADI Required Write
68 97 C0 ; ADI Required Write
68 3D 10 ; ADI Required Write
68 3E 69 ; ADI reccommended writes
68 3F 46 ; ADI reccommended writes
68 4E FE ; ADI reccommended writes
68 4F 08 ; ADI reccommended writes
68 50 00 ; ADI Recommended Write
68 57 A3 ; ADI reccommended writes
68 58 07 ; ADI reccommended writes
68 83 FC ; Enable clock terminators for port A & B
68 84 03 ; ADI reccommended writes
68 85 10 ; ADI recommended setting
68 86 9B ; ADI recommended setting
68 89 03 ; ADI recommended setting
68 9B 03 ; ADI recommended setting
68 93 03 ; ADI recommended setting
68 5A 80 ; ADI recommended setting
Thanks
