AD7606: Inconsistent output value
Question asked by simba on Aug 14, 2014
Latest reply on Aug 20, 2014 by r.daemon@tugraz.at
I am using AD7606 eval board & have interfaced it with a Arduino [intel galileo] board.
I have written a test program to verify the hardware[before going ahead and adding as linux driver], I see inconsistency in the output code values.
I connect channel 1 to a constant supply voltage, following output code value range is what is being seen on the serial output console.
SlVoltage ValueOutput Code Range
1+5V29000 ~ 61000
20V0 ~ 30000
3-5V0 ~ 30000
I have hard wired
1. Range & Stbl pin to Vdrive,
2. Grounded OS0~2.
3. Grounded Data lines D0 ~ D6, D9 ~ D15.
4. Removed R3 & connected R4. [Converting parallel to serial mode.]
I have applied a RESET pulse of 1 micro sec [min available in arduino boards], at the start.
I have connected BUSY signal to interrupt pin, & I am doing chip select & SPI read operations inside the ISR.
I have attached 2 images of the timing diagram
Image 1:
Ch2: Blue:    CONVST signal
Ch1: Yellow: BUSY
Ch3: Pink:    ~CS
Ch4: Green   DoutA / MISO
Image 2:
Ch1: Yellow: BUSY
Ch3: Pink:    FirstData
Please let me know how I can debug this issue.
Regards
Simba
