ADXL 212 : Alignment error between X and Y : a mistake ?
Question asked by azimuth on Aug 13, 2014
Latest reply on Aug 13, 2014 by venkat
Good afternoon,
In the first page of the ADXL 212 datasheet is indicated an alignment error of 0.1 degrees between the X and Y outputs, that is a common value for the accelerometers. But in its third page is indicated a typical value of 0.01 degrees (not guaranted). How to know what is correct, perhaps that this is a mistake ? So if it is 0.01 degrees, does-it exists other ones that have the same error (I am searching an IC that gives the best). Thank you per advance for your reply.
