Error with ADXL345 Pmod Reference Design with ZedBoard
Question asked by ddub on Aug 12, 2014
Latest reply on Aug 12, 2014 by ddub
Hello all,
I am new to FPGAs.
I am attempting to implement the ADXL345 Pmod Reference Design  on the ZedBoard from
ADXL345 Pmod Xilinx FPGA Reference Design [Analog Devices Wiki]
After correcting the path on the download.bat file and running it, the *.bit is downloaded but the script returns "ERROR: Cannot write to target" when trying to start the program on the ARM.
I am running Windows 7 (64) with Xilinx ISE 14.7 connected to a ZedBoard.  All Jumpers are in their default position.
Full text of Command window:
Xilinx Microprocessor Debugger (XMD) Engine
Xilinx EDK 14.7 Build EDK_P.20131013
Copyright (c) 1995-2012 Xilinx, Inc.  All rights reserved.
Executing user script : ADIEvalBoard.tcl
Programming Bitstream -- ADIEvalBoard.bit
Fpga Programming Progress ............10.........20.........30.........40.......
..50.........60.........70.........80.........90........Done
Successfully downloaded bit file.
JTAG chain configuration
Device   ID Code        IR Length    Part Name
1       4ba00477           4        Cortex-A9
2       23727093           6        XC7Z020
Enabling extended memory access checks for Zynq.
Writes to reserved memory are not permitted and reads return 0.
To disable this feature, run "debugconfig -memory_access_check disable".
CortexA9 Processor Configuration
Version.............................0x00000003
User ID.............................0x00000000
No of PC Breakpoints................6
No of Addr/Data Watchpoints.........4
Connected to "arm" target. id = 64
Starting GDB server for "arm" target (id = 64) at TCP port no 1234
Error Executing User Script : ADIEvalBoard.tcl
Error :: ERROR: Cannot write to target
        AP transaction timeout: ACK = 0x01, expected=0x02)
        Error Address = 0xf8000008
Press any key to continue . . .
