AD7176: how to read channels in order
Question asked by hendrik on Aug 10, 2014
Latest reply on Aug 11, 2014 by hendrik
I'm trying to access an AD7176 from an AVR32 microcontroller via SPI. I can read and write registers fine, but my problem is, when I read the converted data, the channels seem to appear in random order.
For example, the DAC gave the following output in continuous conversion mode, with DATA_STAT set:
800f1b02
800f1d02
800e6401
800e4a01
800e3701
8008f800
80091f00
800f2902
8008dd00
80091000
800efb02
8008ff00
[UPDATE: If I interpret the data correctly, the most sig. three bytes represent the converted 24 bit value, and the least significant byte is the status register. This indicates a channel sequence of 2, 2, 1, 1, 1, 0, 0, 2, 0, 0, 2, 0. Which means the data is almost useless for my application.]
This example was read with CS rising between each read operation, but keeping CS low didn't make a difference. Register configuration was:
GPIOCON: 0
ADCMODE: REF_EN only (0x8000)
IFMODE: DATA_STAT | DOUT_RESET (0x0140)
CHMAP0: EN | AINPOS_AIN1 | AINNEG_AIN0 (0x8020)
CHMAP1: EN | AINPOS_AIN2 | AINNEG_AIN0 (0x8040)
CHMAP2: EN | AINPOS_AIN3 | AINNEG_AIN0 (0x8060)
CHMAP3: AINPOS_AIN1 | AINNEG_AIN0 (0x0020)
Any suggestions?
cheers
Hendrik
