U-boot configuration without parallel flash
Question asked by KenH on Aug 8, 2014
Latest reply on Aug 20, 2014 by Aaronwu
Starting from the bf609-ezkit.h configuration, what is the appropriate approach to remove boot options (in my case, I want to only leave UART and SPI FLASH)?
For removing the parallel NOR flash, I had commented out the following #def's in my config file:
#define CONFIG_SYS_FLASH_CFI_WIDTH     2
#define CONFIG_FLASH_CFI_DRIVER
#define CONFIG_SYS_FLASH_BASE          0xb0000000
#define CONFIG_SYS_FLASH_PROTECTION
#define CONFIG_SYS_MAX_FLASH_BANKS     1
#define CONFIG_SYS_MAX_FLASH_SECT      131
#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS
And added the following:
#define CONFIG_SYS_NO_FLASH
However, arch/blackfin/lib/board.c appears to require CONFIG_SYS_FLASH_BASE (wrapped in an #ifdef for __ADSPBF60x__) in order to set up the CPLB table. Adding an appropriate '&& !defined(CONFIG_SYS_NO_FLASH)' appears to fix the issue.
Is this all that is required? Nothing else missing? Should I have left CONFIG_SYS_FLASH_BASE defined but commented out the others?
