No-os reference design example with fmcomms2 problem.
Question asked by Jetmiri on Aug 6, 2014
Latest reply on Aug 7, 2014 by CsomI
I am running the main.c file on the zedboard. The zedboard is programmed with the bit stream which is generated from the HDL reference design. I incorporated also the console comand driver in my src folder.
1.   But however after the showing all the list of commands I can nopt write in the parallel terminal. How to write the commands in parallel terminal!?
2. I am seeing that there should be a  definition of CAPTURE_SCRIPT in order to activate the adc_capture() in the main.c. I know that there is a capture script available but how to use it, or better how to call it inside the main.c. Or it is enough just to write in the beginning:
#define CAPTURE_SCRIPT.
regards,
jetmir
