Setting up the communication between zedboard and pc via ethernet cable.
Question asked by Jetmiri on Aug 4, 2014
Latest reply on Aug 8, 2014 by larsc
Dear all,
I am using fmcomms2 with zedboard. I am trying to make the data streaming example as it is given in Simulink libiio [Analog Devices Wiki] The problem is that I can not make the board to communicate with my PC. My set up is that I am connecting the zedboard via an ethernet cable with my PC and I am putting both Ip on the same subnet. I am using the IP of zedboard inside the iio_source object. But when I am running the Simulink project as it is given in the upper-mentioned link it gives an error.
I should mention that I am using the SD card to set up the linux on zedboard.
Am I missing something from the setup or what!? How can I make the communication between zedboard and PC via ethernet cable!?
Any help will be appretiated.
Thanks in advance,
Jetmir.
