EPPI Setting for ITU656
Question asked by bf_omg on Aug 4, 2014
Latest reply on Sep 23, 2014 by jobo23
Hi, all,
I am a newbie to BF DSP, and come here to turn to your help, tks.
I have a evb board with ADV7280 video decoder with BF60X.
I can set the ADV7280 in progressive mode, and set bf60x to receive the whole ITU656 frame, and It is okay.
(clock is from adv7280)
But I want to just get the active video only, but if failed, the pic in ram is not correct.
The setting for ITU656 whole frame is follwing:
// PPI Setting
static ppi_timing_t adv728xPpiTiming_480i_YCbCr_60Hz_DEINT =
    1716u,                        /* The total number of sample per line including blanking              */
    1716u, //1440u,                     /* The number of active video samples per line excluding blanking    */
    525u,                      /* The number of lines in a frame including blanking                   */
    525u, //487u,                      /* The number of active video lines in a frame excluding blanking    */
    0u,                        /* The period of VSYNC in clock cycles                                 */
    0u,                         /* The period of HSYNC in clock cycles                                 */
    0u,                        /* The width of VSYNC in clock cycles                                 */
    0u,                         /* horizontal blanking samples                                           */
    0u,                        /* The vertical delay in clock cycles between VSYNC and active data  */
    0u,                        /* The horizontal delay in clock cycles between HSYNC and active data*/
    ADI_EPPI_DMA_TRANSFER_32BIT,/* The DMA transfer size                                            */
    4,                           /* The DMA modifier                                                    */
    0x00402084u                   /* PPI control register                                                  */
I just change the setting of ppi ctl reg to rec active frame, but it failed.
Any doc to explain the detail setting for PPI/DMA for ITU656 rx/tx? (excluding the official HDM)
or How to change the setting for it?
Thanks for your help!
BRs.
