ADV7441A output color is wrong when receiving UXGA HDMI input
Question asked by Jane on Jul 30, 2014
Latest reply on Aug 4, 2014 by mattp
Dear Sir,
It is said in the datasheet that ADV7441A incorporates a dual-input HDMI-compatible receiver that supports  display resolutions up to UXGA.
When the customer use ADV7441A receiving 1600X1200@60Hz HDMI input, the output color is wrong (during some tests the output display is green, some tests the output display is colorless). The attached pics are about ADV7441A abnormal output.
Below content is the script which is used now. Is there any necessary content should be modified when the input signal is UXGA (f >160MHz)? Also tested HDMI input resolution lower than 1600X1200@60Hz, the output works very well.
##HDMI PORTA out through ADV7341 Encoder ##
:Port A 1080i 60Hz 25Mhz <  f < 160MHz  YPrPb 422 20Bit IN YPRPB 422 20Bit OUT through Encoder cable Equalizer:
50 10 06 ; Encoder output channel enabled ?36 Bit
50 11 05 ; Bus reordering
50 19 01 ; ADV7441A Video Input Module
50 1B 02 ; Rev E Video Output Module
50 03 03 ; Enable Port A
42 03 0C ; Disable TOD
42 05 06 ; Prim_Mode =0110b HDMI
42 1D 40 ; Disable TRI_LLC
42 6B D1 ; Setting cp_op_sel = 1. 656 Enabled
42 68 F0 ; Auto CSC , YPrPb out
42 F4 3F ; Max Drive Strength
42 BA A0 ; Enable HDMI and Analog in
42 C8 08 ; Digital Fine Clamp Start position
62 F0 10 ; ADI Recommended Write
62 F1 0F ; ADI Recommended Write
62 F4 20 ; ADI Recommended Write
6A 15 EC ; Disable these mute mask bits
6A 1C 49 ; Set MCLKOUT to output 256fs
6A 1D 04 ; & Set Unmute Delay to 1_5 sec.
6A 5A 01 ; Reset Audio Pll
Best Regards!
Jane
