SPI Interfacing between ADIS16210 and mbed LPC1768
Question asked by Oscar_Espejo on Jul 29, 2014
Latest reply on Aug 20, 2014 by NevadaMark
I'm tryng to connect an ADIS16210 to a mbed LPC1768 development board. I search fore some tutorials to document me, so I programm this code to get the information about (at least) one inclination sensor:
#include "mbed.h"
#define SERIAL_BAUD_RATE    9600
Serial pc(USBTX, USBRX); // tx, rx
SPI spi(p5, p6, p7); // mosi, miso, sclk
DigitalOut cs(p8);
DigitalOut led(LED1);
int main() {
    spi.format(16,3);
    spi.frequency(500000);
    cs = 1;
    led = 1;
    int temp;
while (1) {
        cs = 0;
        led=0;
        spi.write(0x0c00);
        wait_ms(500);
        temp = spi.write(0x00); //*1
        cs = 1;
        led = 1;
        pc.printf("Register Data: %d\r\n", temp); //
        wait(1); // wait a sec.
This is the last code I used, because after that I try about 10 codes without the 500ms delay for example with the same result that is the result is the same lat number that I send, dor example if I replace the line  "*1" by temp = spi.write(0xC0); the result is 0xC0 and so on...
Then, I use an scope to analyze the signals in MISO and MOSI and found someting extrange, in the next image is the signal in CLK for reference:
Then I save the signal of MISO unplugged to the sensor (that is remarkable that is in fact the 0x0c00 number):
And then Connected to the sensor:
Now, the signal in MOSI is the same of MOSI when is connected... that have two voltaje falls, I search abot the need to use pull up resistors but in no place tells something about so I don't take the risk.
The other issue was thatr the datasheet shows the ADIS connected to an 3.3V power source but when I connect the sensor to the mbed 3.3V output the DIO1 pin don't respond (that is the sensor is not refreshing the data) so I connected to the 5V pin and then the DIO1 pin responds but the signal is the same with the same issues..
I spend all my ideas and resources and honestly I don't know how to proceed with this.
Thanks in advance for the help!!!
