AD9911 general questions
Question asked by tweekzilla on Jul 29, 2014
Latest reply on Jul 31, 2014 by sitti
Hi all,
I have some pretty basic questions and a possible board design screw up.  My initial aim is to simple read out the CSR register (0x00). I'm using a 3-wire SPI interface (and attempt to set the CSR <2:1> to 01) - Method:
SET REGISTER
1) set CS low
2) Send 0x00 (write to CSR register)
3) Send 0b11110010 (enable 3-wire)
4) set CS high
5) set io_update high
6) set io_update low
READ REGISTER
1) set CS low
2) send 0b10000000 (read CSR register)
3) send 0x00 (and look at what is on the SDIO_2 pin on a scope)
4) set CS high
I'm currently not seeing any bits on the pin, however, below might explain why and any input is appreciated
1) I stupidly tied MASTER_RESET to PWR_DWN_CTRL to GND on the board.  Do I have to do a MASTER_RESET on power up? Someone mentioned in another post that you may be able to initate a MASTER_RESET by sending 32 1's to the chip?
2) I'm waiting for my balun to turn up so I do not have a REF_CLK.  Will the DDS register read just not work without this (I suspect this is my issue)?
