The problem with SPORT simulating UART Rx
Question asked by Joshua on Sep 11, 2010
Latest reply on Sep 27, 2010 by Joshua
  Now i am using SPORT1 as UART on ADSP-BF561 EVB.
  The SPORT TX with DMA2_3 & interrupt mode is OK as that is said in the EE-191.
  But the SPORT Rx is more boring, I do not know how could I make it.
  Here is my main codes:
  /* Init SPORT   */
  void InitSPORT(void)
    *pSPORT1_RCR1   = 0;
    *pSPORT1_RCR2   = 0;
    *pSPORT1_RFSDIV    = 0x0020;
    *pSPORT1_RCLKDIV  = 0x00BC;   //  390MHz/(3*(2*115k2)) ,following EE191.
    *pSPORT1_RCR2       = 0x001F;
    *pSPORT1_RCR1       = 0x0413;
    ssync();
/* ReadSport1   */
HESULT ReadSport1(UINT32 TaskID, void *buf, UINT16 length, DEV_WORK_MODE sync_or_overlapped, Interrupt func)
     UINT16  temp;
     UINT8   *Rx_buf;
     UINT8   *ptr;
     UINT32 *buffer;
     Rx_buf  = (UINT8 *)buf;
     buffer    = (UINT32 *)malloc(length * sizeof(UINT32));
     if(DEV_Sync == sync_or_overlapped)
     else
          *pSPORT1_RCR1   &= ~RSPEN;       //Disable SPORT1
          ssync();
          *pDMA2_2_CONFIG           = 0;
          *pDMA2_2_START_ADDR  = buffer;
          *pDMA2_2_X_COUNT        = length;
          *pDMA2_2_CONFIG          = 0x008A;     // Interrupt mode
          ssync();
          *pDMA2_2_CONFIG         |= DMAED;      // enable DMA
          ssync();
          *SPORT1_RCR1              |= RSPEN;                  // enable SPORT
          ssync();
     Unpack_Data(buffer, Rx_buf, length);                        // getting UART 8bit data.
     free(buffer);
     return 0;
/*  Unpack_Data   */
//  UINT32 *buf_in   => The data buffer received from SPORT1(Following the UART format)
//                               The wide of data is 29bits.(By EE191)
//  UNIT8   *buf_out => The REAL data needed.
//  UINT16  length
void Unpack_Data(UINT32 *buf_in, UINT8 *buf_out, UINT16 length)
     UINT32  *ptr1;
     UINT8   *ptr2;
     UINT8        i;
     UINT32 temp;
     UINT8  data = 0;
     for(ptr1 = buf_in, ptr2 = buf_out; ptr1 < buf_in + length; ptr1++; ptr2++)
          for(i=0; i<8; i++)
               temp = 0x00000008 << (i + 1);     // Getting valid data
               temp = *ptr1 & temp;                   // Bit(3,6,9,...,24) wil be sampled.
               temp >>=(i + 1) * 2 + 1;
               data     |= (UINT8)temp;
          *ptr2          = data;
Some doubts is here.
1) Is the function of Unpack_Data OK? If not, How can l DO it ? Please in C,NOT in assemble.
2) How could I make the the SPORT_RXIsr ?
