error when compile buildroot-2012R1-RC6-BF60X.tar.bz2 for bf609
Question asked by tingkman5 on Jul 23, 2014
Latest reply on Jul 24, 2014 by tingkman5
hi:
    i have a problem when compile  buildroot-2012R1-RC6-BF60X.tar.bz2 ,
    i download  these toolchains blackfin-toolchain-2012R1-RC2.i386.tar.bz2-blackfin-toolchain-elf-gcc-4.3-2012R1-RC2.i386.tar.bz2-blackfin-toolchain-uclibc-default-2012R1-RC2.i386.tar.bz2 and  buildroot-2012R1-RC6-BF60X.tar.bz2
    then unzip the toolchains
    then
      when i make ,error is coming ,the log  is
e information... Done
The following extra packages will be installed:
  libftdi1
The following NEW packages will be installed:
  libftdi-dev libftdi1 libusb-dev
0 upgraded, 3 newly installed, 0 to remove and 778 not upgraded.
Need to get 184 kB/235 kB of archives.
After this operation, 1,699 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
  libftdi1 libusb-dev libftdi-dev
Install these packages without verification [y/N]? y
Get:1 http://cn.archive.ubuntu.com/ubuntu/ precise/main libftdi-dev i386 0.19-4 [184 kB]
Fetched 61.1 kB in 3s (16.4 kB/s)
Selecting previously unselected package libftdi1.
(Reading database ... 205450 files and directories currently installed.)
Unpacking libftdi1 (from .../libftdi1_0.19-4_i386.deb) ...
Selecting previously unselected package libusb-dev.
Unpacking libusb-dev (from .../libusb-dev_2%3a0.1.12-20_i386.deb) ...
Selecting previously unselected package libftdi-dev.
Unpacking libftdi-dev (from .../libftdi-dev_0.19-4_i386.deb) ...
Processing triggers for doc-base ...
Processing 2 added doc-base files...
Processing triggers for man-db ...
Setting up libftdi1 (0.19-4) ...
Setting up libusb-dev (2:0.1.12-20) ...
Setting up libftdi-dev (0.19-4) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
william@lnx:buildroot$ make
>>> inetutils 1.8 Building
PATH="/home/william/609/work/buildroot/output/host/bin:/home/william/609/work/buildroot/output/host/usr/bin:/home/william/609/work/buildroot/output/host/usr/sbin/:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/william/eds/ubootkernel/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux/bin/:/home/william/609/opt/uClinux/bfin-linux-uclibc/bfin-linux-uclibc/bin:/home/william/609/opt/uClinux/bfin-linux-uclibc/bin:/home/william/609/opt/uClinux/bfin-uclinux/bin:/home/william/609/opt/uClinux/bfin-uclinux/bfin-uclinux/bin:/home/william/609/opt/uClinux/bfin-elf/bin:/home/william/609/opt/uClinux/bfin-elf/bfin-elf/bin" PERLLIB="/home/william/609/work/buildroot/output/host/usr/lib/perl"  /usr/bin/make -j2  -C /home/william/609/work/buildroot/output/build/inetutils-1.8/
make[1]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8'
/usr/bin/make  all-recursive
make[2]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8'
Making all in lib
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/lib'
make[4]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/lib'
make[5]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/lib'
make[5]: Nothing to be done for `all-am'.
make[5]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/lib'
make[4]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/lib'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/lib'
Making all in libinetutils
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libinetutils'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libinetutils'
Making all in libtelnet
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libtelnet'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libtelnet'
Making all in libicmp
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libicmp'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libicmp'
Making all in libls
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libls'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/libls'
Making all in src
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/src'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/src'
Making all in telnet
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/telnet'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/telnet'
Making all in telnetd
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/telnetd'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/telnetd'
Making all in ftp
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ftp'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ftp'
Making all in ftpd
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ftpd'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ftpd'
Making all in talk
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/talk'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/talk'
Making all in talkd
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/talkd'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/talkd'
Making all in whois
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/whois'
/usr/bin/make  all-am
make[4]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/whois'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/whois'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/whois'
Making all in ping
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ping'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ping'
Making all in ifconfig
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ifconfig'
Making all in system
make[4]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ifconfig/system'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ifconfig/system'
make[4]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ifconfig'
make[4]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ifconfig'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/ifconfig'
Making all in doc
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/doc'
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/doc'
Making all in man
make[3]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/man'
make man TOOL=rcp SECTION=1
make man TOOL=rsh SECTION=1
make[4]: Entering directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/man'
make[4]: warning: jobserver unavailable: using -j1.  Add `+' to parent make rule.
/bin/sh /home/william/609/work/buildroot/output/build/inetutils-1.8/build-aux/missing --run help2man     \
  --source='GNU inetutils 1.8'  \
  --include=./rcp.h2m  \
  --output=rcp.1  \
  --section 1   \
  `echo ../rcp/rcp | sed s,../ping6/ping6,../ping/ping6, | sed s,../hostname/hostname,../src/hostname, | sed s,../inetd/inetd,../src/inetd, | sed s,../logger/logger,../src/logger, | sed s,../rcp/rcp,../src/rcp, | sed s,../rexec/rexec,../src/rexec, | sed s,../rexecd/rexecd,../src/rexecd, | sed s,../rlogin/rlogin,../src/rlogin, | sed s,../rlogind/rlogind,../src/rlogind, | sed s,../rsh/rsh,../src/rsh, | sed s,../rshd/rshd,../src/rshd, | sed s,../syslogd/syslogd,../src/syslogd, | sed s,../tftp/tftp,../src/tftp, | sed s,../tftpd/tftpd,../src/tftpd, | sed s,../traceroute/traceroute,../src/traceroute, | sed s,../uucpd/uucpd,../src/uucpd,`
  --include=./rsh.h2m  \
  --output=rsh.1  \
  --section 1   \
  `echo ../rsh/rsh | sed s,../ping6/ping6,../ping/ping6, | sed s,../hostname/hostname,../src/hostname, | sed s,../inetd/inetd,../src/inetd, | sed s,../logger/logger,../src/logger, | sed s,../rcp/rcp,../src/rcp, | sed s,../rexec/rexec,../src/rexec, | sed s,../rexecd/rexecd,../src/rexecd, | sed s,../rlogin/rlogin,../src/rlogin, | sed s,../rlogind/rlogind,../src/rlogind, | sed s,../rsh/rsh,../src/rsh, | sed s,../rshd/rshd,../src/rshd, | sed s,../syslogd/syslogd,../src/syslogd, | sed s,../tftp/tftp,../src/tftp, | sed s,../tftpd/tftpd,../src/tftpd, | sed s,../traceroute/traceroute,../src/traceroute, | sed s,../uucpd/uucpd,../src/uucpd,`
help2man: can't get `--help' info from ../src/rsh
Try `--no-discard-stderr' if option outputs to stderr
help2man: can't get `--help' info from ../src/rcp
make[4]: *** [man] Error 1
make[4]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/man'
make[3]: *** [rsh.1] Error 2
make[3]: *** Waiting for unfinished jobs....
make[3]: *** [rcp.1] Error 2
make[3]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8/man'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/william/609/work/buildroot/output/build/inetutils-1.8'
make: *** [/home/william/609/work/buildroot/output/build/inetutils-1.8/.stamp_built] Error 2
william@lnx:buildroot$ sudo apt-get install help2man
Reading package lists... Done
Building dependency tree
Reading state information... Done
help2man is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 778 not upgraded.
Making all in lib
Making all in libls
Making all in src
Making all in ftp
Making all in ftpd
Making all in talk
Making all in talkd
Making all in whois
Making all in ping
Making all in doc
Making all in man
  --output=rcp.1  \
  --section 1   \
  --output=rsh.1  \
  --section 1   \
the red word is error ,can you help me what i do
best wishes
