ADV7611 and ADV7513 voltage translation
Question asked by RajaAshutosh on Jul 16, 2014
Latest reply on Jul 16, 2014 by GuenterL
In the datasheets of 7611 and 7513, it is mentioned that HPD, DDC_SCL, DDC_SDA and CEC pins are 3.3V input, which are 5V tolerant. I see that in the EVMs of 7611 and 7513, no voltage translation from 3.3V to 5V is done. They are directly pulled to 5V supply. (and a ESD protection is provided). Can you please confirm if it is safe to use it without voltage translation circuit and using them as 5V inputs/outputs. Also, can you please also specify the maximum voltage that it can withstand (i.e. above 5V) so that i can cross-check with the power supply tolerance?
