Maximal rate for serial communications with AD9681
Question asked by kotoo@fujiele.co.jp on Jul 7, 2014
Latest reply on Jul 10, 2014 by DougI
Please teach me about AD9681.
1).
The following description is in the data sheet.
Rev. A | Page 26 of 40
Data from each ADC is serialized and provided on a separate channel in two lanes in DDR mode.
The data rate for each serial stream is equal to 16 bits times the sample clock rate,
with amaximum of 500 Mbps/lane [(16 bits*125 MSPS)/(2 × 2) =500 Mbps/lane)].
The lowest typical conversion rate is 10 MSPS.
See the Memory Map section for details on enabling this feature.
I think as follows.
The data rate : 16 bits*125 MSPS=2Gsps.
The lane data rate : 2Gbps/2=1Gbps/lane
The sample clock rate : 2Gbps/2lane/2=500MHz.
Could you teach the above-mentioned?
2).
Please teach in relation to the question on 1).
When using it by the following setting, how many is the LVDS maximum clock of ANSI-644 of 1Lane?
Figure 8. Wordwise DDR, One-Lane, 1× Frame, 12-Bit Output Mode
Do you support it to following 750MHz?
12bit*125M/2=750MHz
Thank you.
