How read three load cells one at a time?
Question asked by renato62 on Jul 2, 2014
Latest reply on Jul 14, 2014 by JohnnyG
I would like to read in the shortest possible time three load cells.
These three load cells are connected to three ad7195 and these are connected to a microcontroller.
The lines common to all three ad7195 and the microcontroller are: DataIn, DataOut and Serial Clock.
With / CS1, / CS2 and / CS3 I enable one at a time the three ad7195.
INIT
I program every ad7195 going down the / CS.
I enable each ad7195 continuous reading.
READ
1)enable / CS1 and expect the signal / RDY is low
I read the data in 24-bit
2) I disable / CS1, enable / CS2 and expect the signal / RDY is low
3)I disable / CS2, enable / CS3 and expect the signal / RDY is low
I go back to step 1)
But the readings are incorrect!
The signal / SYNC in this read mode should be used?
If / CS is high in any case continue the conversion or the ad7195 converts only if the / CS is low?
Does anyone have a sample program?
or has already run a continuous readout of multiple cells?
thanks
Renato
