Tone generator and Detector
Question asked by RicardoAT on Aug 27, 2010
Latest reply on Aug 30, 2010 by RicardoAT
I made a test with Tone Generator and Tone Detector softwares modules at the same VDK project.
I copied almost same examples code of this two softwares modules.
For test, i run the detector fist (finding samples from a file disc). The detector work well, as expected.
After i run the generator (saving the samples at the same file name). Apparently work well.
Then run de detector again, using de newest samples. The detector not work more.
I had a same problem with DTMF softwares modules.
Well, i applyed the same solution, and the detector returned to work.
The solution, after run the function "adi_sigtoneg_Process", put the intruction "asm("L1 = 0;");".
Apparently is working well.
