Building Linux kernel with NFS for Zynq ZC706 with ADV7511 support
Question asked by guraaf on Jun 19, 2014
Latest reply on Jun 19, 2014 by guraaf
Hello all,
I am trying to get ADV7511 working with the Xilinx Zynq ZC706 board. The default out-of-the-box SD card works. I was also able to compile the HDL in Vivado and use that system bitfile.
Now, I was trying to use the Linux but realized that it doesn't come with NFS compiled so wanted to rebuild the kernel. I downloaded the source code and built it but am getting a kernel panic. Any pointers appreciated.  My (incorrect?) steps so far:
$ git clone https://github.com/analogdevicesinc/linux.git linux-adi
$ cd linux-adi
$ git checkout xcomm_zynq_3_8
$ ARCH=arm CROSS_COMPILE=arm-xilinx-linux-gnueabi- make zync_xcomm_adv7511_defconfig xconfig
# checkbox select the NFS portions
$ ARCH=arm CROSS_COMPILE=arm-xilinx-linux-gnueabi- LOADADDR=0x8000 make uImage
$ cd arch/arm/boot/dts
$ ../../../../scripts/dtc/dtc -I dts -O dtb -o zynq-zc706-adv7511.dtb ../devicetree.dtb
$ cd ..
$ sudo mount /dev/sdc1/ /media/boot
$ sudo cp uImage devicetree.dtb /media/boot
The console of the Zynq board is as follows (the BOOT.BIN is something that works with the original uImage and devicetree). Thanks a lot for reading and your pointers.
U-Boot 2012.10 (Mar 22 2013 - 14:07:04)
DRAM:  1 GiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
SF: Detected S25FL129P_64K with page size 64 KiB, total 32 MiB
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
## Error: "run" not defined
zynq-uboot> run sdboot
Device: SDHCI
Manufacturer ID: 28
OEM: 4245
Name:
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.5 GiB
Bus Width: 4-bit
reading uEnv.txt
** Unable to read "uEnv.txt" from mmc 0:1 **
Copying Linux from SD to RAM...
reading uImage
2967008 bytes read
reading devicetree.dtb
10127 bytes read
reading uramdisk.image.gz
5619967 bytes read
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.8.0-ga6ab43a
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2966944 Bytes = 2.8 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fffa000, end 1ffff78e ... OK
Starting kernel ...
Error: unrecognized/unsupported device tree compatible list:
[ 'xlnx,zynq-7000' ]
Available machine support:
ID (hex)    NAME
ffffffff    ARM-Versatile Express
000008e0    ARM-Versatile Express
00000d32    Xilinx Zynq Platform
Please check your kernel config and/or bootloader.
