bf609_Power_On_Self_Test example of RSI interface can not be read continuously .
Question asked by qian on Jun 19, 2014
Latest reply on Jun 19, 2014 by qian
HI,
Chip Version 0.0
Board of AVNET
CCES 1.0.2
I tested "ADSP-BF609_Evaluation_Board-Rel1.0.3\BF609_EZ-Board\Blackfin\Examples\Power_On_Self_Test\sd_test.c" samples.
Routine is not a problem.
But I do some under modification, a modification in the following areas :
int ii;
uint32_t RSI_WriteRead_Test_Multi(uint32_t * pReadBuffer, uint32_t *pWriteBuffer, uint32_t buffer_size, RSI_DATA_BUS_WIDTH bus_width)
    uint32_t i = 0;
    uint32_t error = 0;
    DEBUG_SUBHEADER2( "Multiple Block Test" );
    DEBUG_PRINT("\nSetting device to %d-bit bus", bus_width);
    CYCLES_INIT(benchmarks_multi.MultipleBlockWrite);
    CYCLES_INIT(benchmarks_multi.MultipleBlockRead);
    error = sd_mmc_set_bus_width(bus_width);
//----------------here----------------------------------------------------------------
    asm("nop;");  //Successive calls RSI_ReadMultipleBlocks functions.
    for(int ii=0; ii<100; ii++)
    RSI_ReadMultipleBlocks(i, pReadBuffer, ((buffer_size*4)/512));
    if(!error)
In the second call , enter an infinite loop .
    do{
        while(!(*pREG_RSI0_XFRSTAT & BITM_RSI_XFRSTAT_DATBLKEND));
    }while(!(*pREG_RSI0_XFRSTAT & BITM_RSI_XFRSTAT_DATEND));
thank you.
