Current Sinking of Refin/Out pin on AD7323
Question asked by cwhiteman on Jun 18, 2014
Latest reply on Sep 14, 2014 by KarenNE
When you wish to select the enhanced input range of the AD7323, the data sheet states to apply +3V to the Refin/out pin.  Under absolute Max Ratings' it states that the maximum input current is 10mA, excluding the supplies. Does this pin then count as a ‘supply’? Also, I do not see a minimum current required for the pin in the data sheet.
What is the max and min current that the Refin/out pin can sink when operated in normal mode and in full shutdown mode?
Below is the data sheet for the AD7323:
http://www.analog.com/static/imported-files/data_sheets/AD7323.pdf
Thanks, Cam
