HCC Embedded Flash Translation Layer License
Question asked by akash4488 on Jun 10, 2014
Latest reply on Jun 10, 2014 by CraigG
Branched from an earlier discussion
Hi Martin,
I am working with a customised board based on BF548 and having a micron 2gb nand flash ,64mb ram and usb otg.
When i run the USB mass storage example (which is there in the VISUAL dsp++ 5 sofwtare) and i have made the following configurations in the code as follows
#define _USE_ONBOARD_PERSISTENT_MEDIA in mass_storage_app.c
and
#define DEVICE_TYPE DEVICE_NAND
i bsp_bf548.c
then it gives the following error
IT fails at the following line in mass_storage_app.c
/* If HD is NOT connected to this board */
       if (Result == ADI_DEV_RESULT_SUCCESS)
{printf("\nsucess to Register the PID with the class driver");}
     if(Result != ADI_DEV_RESULT_SUCCESS)
        failure();
and the error is
!!!! A valid license has not been found !!!!
    Please contact HCC Embedded (www.hcc-embedded.com) to arrange a license.
I would be helpful if you can please tell a workaround to overcome this problem
