CCES 1.0.3 Memory browser issue
Question asked by MikeSmithCanada on Jun 5, 2014
Latest reply on Jun 10, 2014 by DavidS
I have a library project myLib.dlb
volatile int dummy1 = 1;
volatile int dummy2 = 2;
volatile int dummy3 = 3;
void Somefunction(void) {   Some code }
and I have a main.cpp that is linked to that library using a path set in settings | linker |general
extern volatile int dummy1;
extern volatile int dummy2;
extern volatile int dummy3;
volatile int dummy4 = 4;
void main(void) {
     printf("%d %d\n",  dummy1, dummy2);
I can compile and run the code
Then I reload the code and ask the memory browser to find and display no problems
But the memory browser can't find dummy1
I generate a map and could find dummy1 in both name mangled and non-name mangled form
Wondering if it was a name mangling issue I tried
both
extern "C++"  volatile int dummy1;
extern "C"  volatile int dummy1;
in both case Memory Browsaer could now find dummy1
so I went back to
-- and that worked --
however none of these tricks worked with dummy2 and memory browser
I have tried clean and refresh on the project -- nothing helps
This is the first step of my group trying to access variables from a CCES plugin we are making -- but if I can't access the variables via memory browser then I suspect I am not going to get anything working from inside the plugin
