Issue on UART Rx and Tx?
Question asked by Karthickph on Jun 5, 2014
Latest reply on Jun 6, 2014 by MMA
Hi, I'm facing a strange issue in ADuC7060 micro while developing the software for our product.  The issue is that when I receive the bytes through UART from an application I can't see the read bytes in order in the stored array of buffer; however if I see the memory location of the array of buffer it looks perfect in order.  I don't why this problem comes, I never seen such a problem before....I used below arrays for store the data and Rx buffer full interrupt to store the bytes in sequence....Please suggest on this issue....
//transmit buffer
UCHAR hc_tx_buffer[40];
//receive buffer
UCHAR hc_rx_buffer[40];
Init function:
GP1CON  = BIT0 + BIT4;
// Enable access to COMDIV registers
COMCON0 = BIT7;
// Set baud rate to 1200
COMDIV0 = 0x0A;
COMDIV1 = 0x01;
//8 bits word lenth, 1 stop bit
COMCON0 = BIT0 + BIT1;
// Enable UART interrupts when Rx full and Tx buffer empty.
// COMIEN0 = BIT0 + BIT1;
COMIEN0 = BIT0; //+ BIT1;  // Enable UART interrupts when Rx full
Karthick
