Questions about 9984A
Question asked by StevenWeyrich on Jun 5, 2014
Latest reply on Jun 5, 2014 by DaveD
I've two questions to the AD9984A:
1. This IC however has a 10 bit output, but it might possible be converted to 8 bit as needed by the TFT display by adjusting the gain and/or offset registers of the AD9984A?
2. Do you know if the AD9984A is able to receive a resolution as low as 480x272 and what the output clock speed would be in this case?
The Application is to use a 4.3" FTF Display with DVI/VGA/DisplayPort. But it is only capable to work with 12 MHz.
So far can I downstreem the DVI/ Displayport Data to a lower data rate?
Thanks!
