block based talk through example adsp21369 - modfy blocks, amplify, filtering
Question asked by mettym on Jun 4, 2014
Latest reply on Jul 7, 2017 by apple_srf
Hello everybody
I am new in the DSP world. I'm programmed a lot of C with microcontrollers and have now a few problems.
In the file 'blocProcess.c' there I will to begin make easy modifications with the data. First I tried to make a simple amplification with the data:
void processBlockAmp(unsigned int *block_ptr, int amp)
     int i;
     float temp_out;
     /*Clear the Block Ready Semaphore*/
     blockReady = 0;
     /*Set the Processing Active Semaphore before starting processing*/
     isProcessing = 1;
      for(i=0;i<NUM_SAMPLES;i++)
          *(block_ptr+i) =  *(block_ptr+i) * amp;
      Block_Float_To_Fixed(block_ptr, f_block_l, f_block_r );
     /*Clear the Processing Active Semaphore after processing is complete*/
     isProcessing = 0;
But there the result was not the expectet one.. then I read in this forum a little bit about this example and foundet here to functions to convert the block from int to a floating point block. So I had:
Block_Fixed_To_Float(block_ptr, f_block_l, f_block_r );
          f_block_l[i] *=amp;
          f_block_r[i] *=amp;
But I could no see any changes of the signal. Firstly I wanted to play with the gain, then built in any filters. How can I make that?
