Config ADV7612 and ADV7511
Question asked by SOO3931123 on May 30, 2014
Latest reply on May 30, 2014 by DaveD
Hi ADI engineers!
I am using your ADV7612 and ADV7511 IC,.The 7612 does not operate. I was hoping you provide any clues as to why the ADV7612 does not output video?
MyADV7612  IIC config data is below
  16'd0: config_data = 8'h98;        //Slave address
  16'd1: config_data = 8'hF4;        //Base register address
  16'd2: config_data = 8'h80;        //CEC MAP I2C address
  16'd3: config_data = 8'h98;        //Slave address
  16'd4: config_data = 8'hF5;        //Base register address
  16'd5: config_data = 8'h7C;        //INFOFRAME Map I2C address
  16'd6: config_data = 8'h98;        //Slave address
  16'd7: config_data = 8'hF8;        //Base register address
  16'd8: config_data = 8'h4C;        //DPLL Map I2C address
  16'd9: config_data = 8'h98;        //Slave address
  16'd10: config_data = 8'hF9;        //Base register address
  16'd11: config_data = 8'h64;        //KSV Map I2C address
  16'd12: config_data = 8'h98;        //Slave address
  16'd13: config_data = 8'hFA;        //Base register address
  16'd14: config_data = 8'h6C;        //EDID Map I2C address
  16'd15: config_data = 8'h98;        //Slave address
  16'd16: config_data = 8'hFB;        //Base register address
  16'd17: config_data = 8'h68;         //HDMI Map I2C address
  16'd18: config_data = 8'h98;        //Slave address
  16'd19: config_data = 8'hFD;        //Base register address
  16'd20: config_data = 8'h44;        //CP Map I2C address
/////////set HDMI mode
  16'd21: config_data = 8'h44;        //Slave address
  16'd22: config_data = 8'h6C;        //Base register address
  16'd23: config_data = 8'h00;
  16'd24: config_data = 8'h68;        //Slave address
  16'd25: config_data = 8'h9B;        //Base register address
  16'd26: config_data = 8'h03;
  16'd27: config_data = 8'h68;        //Slave address
  16'd28: config_data = 8'h6F;        //Base register address
  16'd29: config_data = 8'h08;
  16'd30: config_data = 8'h68;        //Slave address
  16'd31: config_data = 8'h85;        //Base register address
  16'd32: config_data = 8'h1F;
  16'd33: config_data = 8'h68;        //Slave address
  16'd34: config_data = 8'h87;        //Base register address
  16'd35: config_data = 8'h70;
  16'd36: config_data = 8'h68;        //Slave address
  16'd37: config_data = 8'h57;        //Base register address
  16'd38: config_data = 8'hDA;
  16'd39: config_data = 8'h68;        //Slave address
  16'd40: config_data = 8'h58;        //Base register address
  16'd41: config_data = 8'h01;
  16'd42: config_data = 8'h68;        //Slave address
  16'd43: config_data = 8'h03;        //Base register address
  16'd44: config_data = 8'h98;
  16'd34: config_data = 8'h4C;        //Base register address
  16'd35: config_data = 8'h44;
////////////////Hot Plug Assert
  16'd36: config_data = 8'h98;        //Slave address
  16'd37: config_data = 8'h20;        //Base register address
  16'd38: config_data = 8'hF8;        //Manually assert hot plug on port A
  16'd39: config_data = 8'h98;        //Slave address
  16'd40: config_data = 8'h20;        //Base register address
  16'd41: config_data = 8'hF4;        //Manually assert hot plug on port B
////////////////set non-fast switching
  16'd43: config_data = 8'hC1;        //Base register address
  16'd44: config_data = 8'h01;
  16'd45: config_data = 8'h68;        //Slave address
  16'd46: config_data = 8'hC2;        //Base register address
  16'd47: config_data = 8'h01;
  16'd48: config_data = 8'h68;        //Slave address
  16'd49: config_data = 8'hC3;        //Base register address
  16'd50: config_data = 8'h01;
  16'd51: config_data = 8'h68;        //Slave address
  16'd52: config_data = 8'hC4;        //Base register address
  16'd53: config_data = 8'h01;
  16'd54: config_data = 8'h68;        //Slave address
  16'd55: config_data = 8'hC5;        //Base register address
  16'd56: config_data = 8'h01;
  16'd57: config_data = 8'h68;        //Slave address
  16'd58: config_data = 8'hC6;        //Base register address
  16'd59: config_data = 8'h01;
  16'd60: config_data = 8'h68;        //Slave address
  16'd61: config_data = 8'hC7;        //Base register address
  16'd62: config_data = 8'h01;
  16'd63: config_data = 8'h68;        //Slave address
  16'd64: config_data = 8'hC8;        //Base register address
  16'd65: config_data = 8'h01;
  16'd66: config_data = 8'h68;        //Slave address
  16'd67: config_data = 8'hC9;        //Base register address
  16'd68: config_data = 8'h01;
  16'd69: config_data = 8'h68;        //Slave address
  16'd70: config_data = 8'hCA;        //Base register address
  16'd71: config_data = 8'h01;
  16'd72: config_data = 8'h68;        //Slave address
  16'd73: config_data = 8'hCB;        //Base register address
  16'd74: config_data = 8'h01;
  16'd75: config_data = 8'h68;        //Slave address
  16'd76: config_data = 8'hCC;        //Base register address
  16'd77: config_data = 8'h01;
////////////set video output
  16'd78: config_data = 8'h98;        //Slave address
  16'd79: config_data = 8'h03;        //Base register address
  16'd80: config_data = 8'h46;        //36-bit SDR 4:4:4 Mode 1
  16'd81: config_data = 8'h98;        //Slave address
  16'd82: config_data = 8'h00;        //Base register address
  16'd83: config_data = 8'h13;
  16'd84: config_data = 8'h98;        //Slave address
  16'd85: config_data = 8'h01;        //Base register address
  16'd86: config_data = 8'h13;
  16'd87: config_data = 8'h98;        //Slave address
  16'd88: config_data = 8'h0C;        //Base register address
  16'd89: config_data = 8'h42;        //0x0C[5]=0; Chip is operational
  16'd90: config_data = 8'h98;        //Slave address
  16'd91: config_data = 8'h15;        //Base register address
  16'd92: config_data = 8'hA0;        //LLC active; Pixel bus active; Sync output pins active
and My ADV7511 IIC config data is below
  16'd0: config_data = 8'h72;        //Slave address
  16'd1: config_data = 8'h41;        //Base register address
  16'd2: config_data = 8'b00010000;
  16'd3: config_data = 8'h72;        //Slave address
  16'd4: config_data = 8'h98;        //Base register address
  16'd5: config_data = 8'h03;
  16'd6: config_data = 8'h72;        //Slave address
  16'd7: config_data = 8'h9A;        //Base register address
  16'd8: config_data = 8'b11100000;  //要求0x9A地址中数据[7:5]=0b111
  16'd9: config_data = 8'h72;        //Slave address
  16'd10: config_data = 8'h9C;        //Base register address
  16'd11: config_data = 8'h30;
  16'd12: config_data = 8'h72;        //Slave address
  16'd13: config_data = 8'h9D;        //Base register address
  16'd14: config_data = 8'b00000001;  //要求0x9D地址中数据[1:0]=0b01
  16'd15: config_data = 8'h72;        //Slave address
  16'd16: config_data = 8'hA2;        //Base register address
  16'd17: config_data = 8'hA4;
  16'd18: config_data = 8'h72;        //Slave address
  16'd19: config_data = 8'hA3;        //Base register address
  16'd20: config_data = 8'hA4;
  16'd21: config_data = 8'h72;        //Slave address
  16'd22: config_data = 8'hE0;        //Base register address
  16'd23: config_data = 8'hD0;
  16'd24: config_data = 8'h72;        //Slave address
  16'd25: config_data = 8'hF9;        //Base register address
  16'd26: config_data = 8'h00;
  16'd27: config_data = 8'h72;        //Slave address
  16'd28: config_data = 8'h16;        //Base register address
  16'd29: config_data = 8'b00100100;  //
  16'd30: config_data = 8'h72;        //Slave address
  16'd31: config_data = 8'h17;        //Base register address
  16'd32: config_data = 8'b00000010;  //
  16'd33: config_data = 8'h72;        //Slave address
  16'd34: config_data = 8'hAF;        //Base register address
  16'd35: config_data = 8'b00000110;  //
When I connect the 7511 to the TV and donot connect the input Video to 7612 ,I found the screen was purple. I was confused about it.
When I connect my computer to  the 7612, the TV do not make any change.
How to config the registers so I can put the video data to the TV ?
P.S.:I need the 1080p@60Hz input and output video, RGB 4:4:4
