Problems with ADXL362 motion detection
Question asked by simon12 on May 28, 2014
Latest reply on May 29, 2014 by neilzhao
Hello everybody!
At present I work with the ADXL362 in order to build a vibration monitoring system. Therefore I would like to use the detection mode of the ADXL to get an interrupt  on the INT1/INT2 when the acceleration exceeds or falls below a defined threshold.
After testing the basic examples from the ADXL362 Arduino library, I tried by myself to compile a program. Unfortunately I got some issues. I would be very nice of you if someone on your side could check if the registers were correctly set.
The program runs with ODR = 400Hz in the measurement mode with an absolute threshold configuration. During a standstill I measure a maximum amplitude of 1250. In my opinion I should get a low output on the INT2-pin when I let run my program with a threshold of 1400 for the activity detection. In fact that’s not the case, the INT2-pin output is high all the time!
I have another question concerning the inactivity mode: Is it correct, that the acceleration on all the 3 axes has to be lower than the threshold in order to be able to detect inactivity?
Thank you very much in advance!
Greetings from Germany!
Simon
Below the register configuration:
Register
Value
0x20
0x78
0x21
0x05
0x22
0x28
0x27
0x01
0x2B
0x10
0x2C
0x17
0x2D
0x02
Arduino Code:
#include <SPI.h>
const int slaveSelectPin = 10;
void setup(){
    Serial.begin(9600);
    pinMode(slaveSelectPin, OUTPUT);
    SPI.begin();
    SPI.setDataMode(SPI_MODE0); //CPHA = CPOL = 0    MODE = 0
    delay(1000);
    // Set Activity Threshold to 1400 -> activity shouldn't be detected (1g = 1250)
    // THRESH_ACT_L
    digitalWrite(slaveSelectPin, LOW);
    SPI.transfer(0x0A);  // write
    SPI.transfer(0x20);  //  Reg 20 THRESH_ACT_L
    SPI.transfer(0x78);  //  Reg 20 = dec 250
    digitalWrite(slaveSelectPin, HIGH);
    delay(100);
    // THRESH_ACT_H
    SPI.transfer(0x21);  //  Reg 21 THRESH_ACT_H
    SPI.transfer(0x05);  //  Reg 21 = 0x05
    delay(100);
    // Set Activity Timer to 40. With ODR = 400Hz after 0.1s activity should be detected
    // TIME_ACT
    SPI.transfer(0x22);  //  Reg 22 TIME_ACT
    SPI.transfer(0x28);  // 40/400 => 0.1 sec
    delay(100);
    // Set Default Mode + Absolute Activity + Activity enable
    // ACT_INACT_CTL
    SPI.transfer(0x27);  //  Reg 27 ACT_INACT_CTL
    SPI.transfer(0x01);  // ACT_EN
    delay(100);
    // Configure INT2: map the activity status to INT2
    // INTMAP2
    SPI.transfer(0x2B);  //  Reg 2B INTMAP2
    SPI.transfer(0x10);  //  ACT
    delay(100);
    // Set Range 2g + Bandwidth 1/4 ODR + ODR = 400Hz
    // FILTER_CTL
    SPI.transfer(0x2C);  //  Reg 2B FILTER_CTL
    SPI.transfer(0x17);  //  ODR 400Hz | HALF_BW | 2g
    delay(100);
    // Select Measurement Mode
    // POWER_CTL
    SPI.transfer(0x2D);  //  Reg 2D
    SPI.transfer(0x02);  // begin meanusre
    delay(100);
    attachInterrupt(0, reset, RISING);
void loop(){
// ISR to handle the Interrupt by reading the STATUS-Register
void reset() {
  SPI.transfer(0x0B);  // write
  SPI.transfer(0x0B);  //  Reg 20 THRESH_ACT_L
  SPI.transfer(0x00);
  Serial.println("interrupt");
