A question about Audio Extract from the ADV7626
Question asked by Jane on May 27, 2014
Latest reply on May 28, 2014 by lcheng
Dear,Sir,
We occur a question about Audio Extract from the ADV7626.
Application :  the video/audio path is RXA --> TXA , and anabling Audio Extract from Receiver.
Testing environment: The HDMI output plug the TV, and the L/R out plug the Aktiv-Lautsprecher(SONY). The AV and the L/R out are narmal. On this condition, do the following test:
(1) Unplug the TV, the L/R out is interrupted, and then it output noise for about 1-3s, after that ,the L/R output back to the normal again.
  For this ,how can I do to avoid the noise? And If I can do that even unplug the TV, but the L/R out isn't interrupted?
(2) Pluging the cable connect to the L/R out continuously. Sometimes, it will lead to no video and no audio on the TV, and the L/R output noise all the time. At this time, such as Internal mute HDMI interrupts is present. I found that the messages.
-R1: 25:762 ----------> Int: Intern Mute=0
-R1: 25:811 ----------> Int: V Lock=1
-R1: 25:854 @@@@ RX started delay to unmute
-R1: 25:910 @@@@ RX Mute State changed to 0
-R1: 25:960 @@@@ RX unmute delay expired
-R1: 26:008 ----------> Int: ACP+
-R1: 26:048 ----------> Int: GMD+
-R1: 26:089 ----------> Int: Aud N Change
-R1: 26:137 ----------> Int: Multi Chan Aud=0
-R1: 26:192 Internal Mute Off
-R1: 26:246 ----------> Int: Aud N Change
-R1: 26:295 HDMI Vsync Filter not locked
-R1: 26:340 There is no corresponding VIC. VIC is set to 0
APP: RX Video Stable =1
APP: last vic = 0
-R1: 26:479 Channel Status: 04 00 10 02 00  N=585595
-T1: 26:544 Setting audio parameters:
             SF=48 KHz  CC=88  HBR=No
-R1: 26:632 Received
Audio Info Frame Packet:
             84 54 f2 62 b2 d0 a5 a6   9f 2f 6e 7d 1a
-R1: 26:757 Error: TX failed to stay encrypted
-R1: 26:820 ----------> Int: Intern Mute=0
-R1: 26:870 ----------> Int: DE REGEN=1
-R1: 26:915 ----------> Int: VLock=0
-R1: 26:960 HDMI Vsync Filter not locked
-R1:27:006 There is nocorresponding VIC. VIC is set to 0
APP: RX Video Stable = 0
-R1: 27:115 @@@@ RX Mute State changed to 2 ……
