Problem with FFT and IFFT
Question asked by Lutrey on May 22, 2014
Latest reply on May 26, 2014 by JJoseph
Hallo,
I got a new problem. I would like to use the fft and ifft.
At first I want build an example to transform my Signal with the fft and transform it back with the ifft.
Later I want calculate the cross-power spectrum but this is not important for my question.
I use the fft an ifft from the trans.h.
I only use in this example the fft and the ifft to the left Signal.
void BPROCESS_Test (SSBlockAlgo* pBlkAlgoInfo)
                int sample=0, blockSize=0;
                blockSize = pBlkAlgoInfo->pInputs[0].pBlockProperties->nBlockSize;
                float SignalL[blockSize], SignalR[blockSize];
                float *pInputL, *pInputR, *pOutputL, *pOutputR;
                pInputL = pBlkAlgoInfo->pInputs[0].pSamples;
                pInputR = pBlkAlgoInfo->pInputs[1].pSamples;
                pOutputL = pBlkAlgoInfo->pOutputs[0].pSamples;
                pOutputR = pBlkAlgoInfo->pOutputs[1].pSamples;
                float L_re_f[blockSize],L_im_f[blockSize], L_re[blockSize],L_im[blockSize];
                for(sample = 0; sample < blockSize; sample++)
                               SignalL[sample] = pInputL[sample];
                               SignalR[sample] = pInputR[sample];
                rfft64(SignalL, L_re_f, L_im_f);
                ifft64(L_re_f, L_re_f, L_re, L_im);
                               pOutputL[sample]=L_re[sample];
                               pOutputR[sample]=SignalR[sample];
If I run this in Sigma Studio, Signal R is ok (as expected). Signal L is very noisy.
I use the rfft64 an ifft64, because the blockSize is 64, too. Is this correct?
Is it correct, that L_re has this size, too?
Can I use the fft and ifft this way or am I totally wrong?
Based on this example I just want to understand, how I could use fft and  ifft correctly.
Best regards
Lukas
p.s. I work on an ADSP-21364 EZ-Kit
