Can the AD5735 be used in single supply configuration?
Question asked by Lionelwallace Employee on May 20, 2014
Latest reply on Feb 26, 2015 by puja4ask
I received this inquiry from a customer:
In our design the AD5735 will only be used in a unipolar output mode, therefore I would like to know if the AD5735 AVss pin can be tied to gnd instead of a negative supply. I would prefer not to have to add a negative supply to the design if it is not necessary.
The datasheet list the range for as -10.8 <= AVss <= -26.4.
  • Is there any way to make the AD5735 work correctly without a negative supply?
  • If not, how much current should the negative supply be capable of sourcing/sinking?
  • Any suggestions for generating the required negative supply.
