AD9361 Loop Test , Repeater Application
Question asked by sss on May 20, 2014
Latest reply on May 26, 2014 by sss
I check the following discussion.
http://ez.analog.com/thread/40747
AD9361 loopback ?
I am confused, can not understand the function of the register.
SPI Register 0x3F5—BIST Config2
D7—Data Port SP, HD Loop Test OE
D0—Data Port Loop Test Enable
I have understood as follows.
Is it Correct?
Q1)
Correct?
Tx Data input>>>TX1 or 2 Port Output >>>Coaxial cable Connect>>>Rx2 or 1 Port Input>>>Rx Data Output
Incorrect?
Rx2 or 1 Port Input>>>Rx Data Output>>>Cable Connect>>>Tx Data input>>>TX1 or 2 Port Output
DATA_CLK>>>FB_CLK
RX_FRAME>>>TX_FRAME
RXDATA>>>TX_DATA
Q2)
Correct?
0x3F5 [D7]
1:Half duplex mode enable
0:Full duplex mode enable? or other?
0x3F5 [D0]
1:Loop test enable?
0:What is this setting / situation?
Q3)
If I design using the AD9361 * 2pcs in digital repeater applications, what solutions would be the best ?
Antenna<>AD9361(1)<>FPGA? BBP?<>AD9361(2)<>Antenna
In the case of  frequency conversion type repeater equipment,
Is it enable, direct connect Data/CLK/Frame ,no FPGA or BBP ,using controler for SPI setting?
Please advice for me.
Thanks.
