Not getting VIC from ADV7511
Question asked by maheshfirke on May 15, 2014
Latest reply on May 27, 2014 by GuenterL
I am using Virtex7 FPGA loaded with RGB generator and this RGB output is connected to ADV7511.
I have Pixel Display Pipeline(PDP) to generate RGB data. The PDP also generated the hsync.vsync and DE.
I am trying for resolution 720P at 60 Hz. The output of PDP is 24bit RGB 4:4:4
I can see the HPD and monitor sense high. I2c Iface is working properly. I can power up the chip completely. But i don't see the proper VIC detected. Also no picture on monitor.
The PLL is locked.
RGB connections to ADV7511
HDMI_D35 to HDMI_D28 <= RED(7 downto 0)
HDMI_D27 to HDMI_D24 <= tied_low(3 downto 0)
HDMI_D23 to HDMI_D16 <= GREEN(7 downto 0)
HDMI_D15 to HDMI_D12 <= tied_low(3 downto 0)
HDMI_D11 to HDMI_D4  <= BLUE(7 downto 0)
HDMI_D3  to HDMI_D0  <= tied_low(3 downto 0)
CLK is set at 74 MHz.
Pasted below is the hardware log, along with my comments.
--Try to read Read-only register of chip to check if I2C iface is working.
%I2C_Read 0x7B 0xF5
0x75
%I2C_Read 0x7B 0xF6
0x11
--Ok. Both registers read correct value. Assume I2c iface is working.
--Now, check status of the HPD and Monitor Sense
%I2C_Read 0x7B 0x42
0x70
--so both HPD and monitor sense are high.
--Power up the device.
%I2C_Write 0x7A 0x41 0x10
%I2C_Read 0x7B 0x41
0x10
--Device is fully powered up
--Write to fixed registers
%I2C_Write 0x7A 0x98 0x03
%I2C_Write 0x7A 0x9A 0xE0
%I2C_Write 0x7A 0x9C 0x30
%I2C_Write 0x7A 0x9D 0x61
%I2C_Write 0x7A 0xA2 0xA4
%I2C_Write 0x7A 0xA3 0xA4
%I2C_Write 0x7A 0xE0 0xD0
%I2C_Write 0x7A 0xF9 0x00
--Disable I2S
%I2C_Write 0x7A 0x0C 0x80
--Select input video format
--24bit RGB 4:4:4 with separate syncs
%I2C_Write 0x7A 0x15 0x00
--Select Colour Depth and output format
-- colour depth = 8 bit
-- output format 4:4:4
%I2C_Write 0x7A 0x16 0x30
-- Select Aspect Ratio
--16:9
%I2C_Write 0x7A 0x17 0x02
--Select Picture Aspect Ratio
--16:9
%I2C_Write 0x7A 0x56 0x2A
--Select HDMI/DVI Mode
--HDMI
%I2C_Write 0x7A 0xAF 0x16
--Now read the VIC
%I2C_Read 0x7B 0x3E
0x00
--VIC is not detected???
--Check PLL lock
%I2C_Read 0x7B 0x9E
0x12
--Yes, it is locked.
