External clock signal changes the ADC AD7190 read values
Question asked by StephanB on May 7, 2014
Latest reply on Jun 2, 2014 by StephanB
I have a circuit with four AD7190s. We read at 24bit accuracy as frequently as the chips allows. Each set of four reads must be absolutely synchronized. We read at full resolution (24bit) from AIN3 and use a common sync pin connected to all four ADCs SYNC pins to ensure the readings are in sync. We have this working using the internal clock. To improve synchronization further we want all four ADCs to use the same external clock signal from a 4.91MHz square wave generator supplied to their MCLK2 pins. The results we get from this external clock are not as expected. Rather than simply tightening up on synchronization it appears that using the external clock affects the ADC Read values.
Results using internal clock. (Mode register  0x80061)
            Reading         Reading / Volts
1V       1,015,291    1,015,291
2V       2,039,035    1,019,518
3V       3,062,847    1,020,949
4V       4,087,029    1,021,757
(Average per volt value = 1,019,379 )
The above shows a reasonably linear relationship.
Using external clock signal on MCLK2 . (Mode register set to 0x40060, actual 0x40061)
1V       876,317        876,317
2V       1,902,749    951,375
3V       2,928,701    976,234
4V       3,955,095    988,774
(Average per volt value = 948,175)
Using the external clock signal changed the results and now they are not just different but they are not linear.
Additional information:
(Internal clock register values)
MODE_REG:0x80061
CONFIG_REG:0x804009
ID_REG:0x85
GPOCON_REG:1
OFFSET_REG:0x800001
FULLSCALE_REG:0x5540E1
CONFIG_REG:8405001
OFFSET_REG:8388609
FULLSCALE_REG:5587169
(External clock signal on MCLK2 register values)
Set MODE_REG: 0x40060
MODE_REG:0x40061
CONFIG_REG:0x804009
ID_REG: 0x85
GPOCON_REG:1
OFFSET_REG:0x800001
CONFIG_REG:8405001
OFFSET_REG:8388609
Please can you see if we have something set wrong or could you improve the way we are doing this. What we need is 24bit accuracy. We are continually reading 4 separate voltage sources ;( X sensor, Y sensor, Z sensor and reference sensor). It is critical that we take all 4 readings at exactly the same time. Any lack of synchronization results in big errors.
The external clock signal used is a 4.91MHz ,5V, square wave,see attached. The square wave is actually a square the slight ripples are down to probe termination rather than a real feature of the square wave. The circuit diagram for the Square wave generator is also attached.
