7842-7511 eval board as VGA->HDMI converter
Question asked by kika on May 7, 2014
Latest reply on Dec 1, 2014 by DSchaefer
Hello all!
I've just received a 7842-7511 Eval board, and before starting working on the project, decided to test its basic functionality. I have a VGA (640x480 text mode computer) source and a DVI monitor. I've connected analog VGA to the EVAL board input and connected HDMI output to DVI-D input of the monitor. I'm expecting Repeater program to allow me see VGA input on HDMI output. No HDCP/encryption involved, computer source, computer monitor sink. Monitor is 1280x1024 (NEC 1990SX). The board was bought at AVNET.
I boot up the board with source and monitor disconnected, I see the '>' prompt, it responds to 'help' command, all is well.
>help
Professional AV Eval Board Software Version: 1.1 built on Oct 29 2010 at 08:53:50
I disable HDCP, since my equipment is purely computer
>rep enc off
ENC OFF
I start the Repeater, source and sink are still disconnected
>startrep
-Rx: 58:153 Configuring RX CSC:   RGB 444 --> RGB 444  (Range=Default)
-Tx: 58:198 #### Muted using: TMDS ASP
-Tx: 58:226 Setting audio parameters:
             SF=32 KHz  CC=2  HBR=No
-Rx: 58:307 @@@@ RX Mute State changed to 2
APP: Freerun is OFF
>-Rx: 58:421 Configuring RX CSC:   RGB 444 --> RGB 444  (Range=Default)
-Rx: 58:433 Source signal changed to DVI
-Rx: 58:436 Received AVI Info Frame Packet:
             02 02 0d 00 08 00 02 00   00 00 00 00 00 00 00 00
             VIC = 2 (720x480p @ 60Hz)
             Colorspace = RGB    PR = 0
-Rx: 58:445 Configuring RX CSC:   RGB 444 --> RGB 444  (Range=Default)
-Tx: 58:474 HPD changed to LOW
-Tx: 58:480 #### Muted using: TMDS ASP
-Tx: 58:508 Setting audio parameters:
APP: The received EDID is empty or corrupted. Default EDID is used for Source
------------------------- EDID BLOCK 0 -------------------------
Edid Version 1.3
Mon Timing:
    Pixel clock = 148.50 MHz
    H Active    = 1920
    V Active    = 1080
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    Pixel clock = 74.25 MHz
    H Active    = 1280
    V Active    = 720
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Name:   HDMI TV
Mon Freq:
    Min V Freq = 29 Hz
    Max V Freq = 86 Hz
    Min H Freq = 15 KHz
    Max H Freq = 111 KHz
Edid extensions blocks: 1
========================= EDID BLOCK 1 =========================
CEA extension block revision 3
Underscan=No  Audio=Yes  YCbCr4:4:4=Yes  YCbCr4:2:2=Yes
Data block collection information:
    Video data block
       * VIC=16
         VIC=4
         VIC=3
         VIC=18
         VIC=1
         VIC=19
         VIC=17
         VIC=7
         VIC=5
         VIC=6
         VIC=34
         VIC=20
         VIC=21
    Audio data block
       Format Code          = 1 (Linear PCM)
        Max. No. of Channels= 8
        Sampling Freq. (KHz)= 32  44.1  48  96  192
        Length (bits)       = 16  20  24
    Speaker allocation data block
       0x4f
       0x00
       0x00
    VSDB data block
SPA location is at 0x9e, SPA = 1.0.0.0
Mon Timing:
    H Active    = 1280
    V Active    = 720
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Timing:
    Pixel clock = 27.0 MHz
    H Active    = 720
    V Active    = 576
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    H Active    = 720
    V Active    = 480
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    H Active    = 1920
    V Active    = 540
    Interlaced
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    H Active    = 1280
    V Active    = 720
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
########################### EDID END ###########################
-Tx: 58:593 Sink is HDMI
APP: EDID received. Setting all ports HPD to LOW.
APP: My phys address is  1.0.0.0
APP: Port 0 Phys Addr is 1.1.0.0
APP: Port 1 Phys Addr is 1.2.0.0
APP: Writing EDID segment 0 to Rx...
-Tx: 58:714 MSEN changed to LOW
APP: Setting all ports HPD to HI.
APP: CEC logical address allocated=5
CEC: Setting My Physical Addr to 1000
CEC: Sending Report phys address=1000
CEC: Sending routing information. Inp=1100
APP: CEC Tx message sent OK
Now I connect output HDMI monitor:
-Tx: 18:557 HPD changed to HI
-Tx: 18:616 MSEN changed to HI
Edid Version 1.3
Mon Timing:
    Pixel clock = 108.0 MHz
    H Active    = 1280
    V Active    = 1024
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Freq:
    Min V Freq = 50 Hz
    Max V Freq = 85 Hz
    Min H Freq = 31 KHz
    Max H Freq = 81 KHz
Mon Name:   LCD1990SX
Mon Serial: 03104788UA
Edid extensions blocks: 0
-Tx: 18:756 Sink is DVI
APP: Changed system mode to Transmitter
APP: Freerun is ON. VIC is 2
-Tx: 19:332 #### Muted using: BLKOUT ASP
-Tx: 19:594 #### Is now un-muted
-Rx: 19:612 Configuring RX CSC:   RGB 444 --> RGB 444  (Range=Default)
-Rx: 19:623 @@@@ RX Mute State changed to 0
APP: CEC logical address allocated=255
CEC: Setting My Physical Addr to 0
CEC: Sending Report phys address=0
CEC: Sending routing information. Inp=6159
I connect VGA source
Edid Version 1.3
Mon Timing:
    H Active    = 1280
    V Active    = 1024
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Freq:
    Min V Freq = 50 Hz
    Max V Freq = 85 Hz
    Min H Freq = 31 KHz
    Max H Freq = 81 KHz
Mon Name:   LCD1990SX
Now I enable VGA input
>vga
analog on
Analog inputs are being processed.
-TvApp: 05:650 --------------------------
-TvApp: 05:652  Selecting Interface Index 0
-TvApp: 05:653 --------------------------
-TvApp: 05:674 TV_EVENT_RX_NEW_IF_REQ Event: Analog-Graphic Input
-Tv:  05:676 Initialising Graphics Interface
-Tv:  05:735 Selecting Graphic Interface as Aux input
-TvApp: 05:741 --------------------------
-TvApp: 05:743  Selecting Interface Index 0
-TvApp: 05:746 --------------------------
-TvApp: 05:766 TV_EVENT_RX_NEW_IF_REQ Event: Analog-Graphic Input
-Tv:  05:769 Initialising Graphics Interface
-Tv:  05:829 Selecting Graphic Interface as Aux input
src 0
-TvApp: 05:836 --------------------------
-TvApp: 05:837  Selecting Interface Index 0
-TvApp: 05:839 --------------------------
-TvApp: 05:859 TV_EVENT_RX_NEW_IF_REQ Event: Analog-Graphic Input
-Tv:  05:861 Initialising Graphics Interface
>-TvApp: 05:932 Configuring Tx CSC:   Y1Y0: 1 YCbCr-601 422 --> YCbCr 422
-TvApp: 05:937 Setting Tx input AR = 16x9
-TvApp: 05:949 TV_EVENT_RX_SYNC_LOCK Event: 0
-TvApp: 05:951 TV_EVENT_RX_AUX_SYNC_LOCK Event: 0
-TvApp: 05:953 TV_EVENT_HDMI_CABLE_DETECT Event: Port 0, Value 0
-TvApp: 05:956 TV_EVENT_HDMI_CABLE_DETECT Event: Port 1, Value 0
-TvApp: 06:036 Configuring Tx CSC:   Y1Y0: 1 YCbCr-601 422 --> YCbCr 422
-TvApp: 06:039 Setting Tx input AR = 16x9
-TvApp: 06:053 TV_EVENT_RX_SYNC_LOCK Event: 0
-TvApp: 06:139 Configuring Tx CSC:   Y1Y0: 1 YCbCr-601 422 --> YCbCr 422
-TvApp: 06:143 Setting Tx input AR = 16x9
-TvApp: 06:156 TV_EVENT_RX_SYNC_LOCK Event: 1
-Tv:  06:255 Video Resolution Information read from HW
             *Sync Source: 1
             *Block Length: 7303
             *Lines/Vsync: 2 Lines
             *Lines/Field: 448 Lines
             *Field Length: 1602
             *Interlaced: No
-MwRx:06:264 No Resolution found for measurements returned by STDI
-Tv:  06:266 No supported Vic detected
-TvApp: 06:267 TV_EVENT_RES_FOUND Event: 1, Table index : 0
-TvApp: 06:269 Configuring Tx CSC:   Y1Y0: 0 RGB 444 --> RGB 444
-TvApp: 06:273 Setting Tx input AR = 4x3
-Tx: 06:319 HDCP and Frame Encryption Enabled
-Tv:  06:330 Mute State changed to 0
-TvApp: 06:332 TV_EVENT_MUTE_CHANGE Event : 0
-Tx: 06:337 HDCP i2c failed error received
-Tx: 06:474 MSEN changed to HI
-Tx: 06:642 HDCP i2c failed error received
-Tx: 06:757 MSEN changed to HI
-Tx: 06:913 HDCP i2c failed error received
-Tx: 07:024 MSEN changed to HI
-Tx: 07:197 HDCP i2c failed error received
-Tx: 07:302 MSEN changed to HI
-Tx: 07:417 HDCP i2c failed error received
-Tx: 07:574 MSEN changed to HI
The last two messages repeat indefinitely, until I reset the board or type in "stoprep".
And nothing happens on the HDMI output screen. The screen is "ON", not going into standby, but there's no picture from VGA. If I connect VGA to monitor directly I see the picture.
Now, the question: What I'm doing wrong and what should I need to do minimally, to turn 7842 EVAL board into a very expensive VGA2HDMI converter?
Kirill
