ADXL345 Android driver
Question asked by Mack on Apr 29, 2014
Latest reply on Apr 29, 2014 by mhennerich
Below is adxl34x's platform data.
If I change the order of values in the array named  .ev_codes_orient_3d = {BTN_Z, BTN_Y, BTN_X, BTN_A, BTN_B, BTN_C} can I make each axis upside down?
#include <linux/input/adxl34x.h>
static const struct adxl34x_platform_data adxl34x_info = {
.x_axis_offset = 0,
.y_axis_offset = 0,
.z_axis_offset = 0,
.tap_threshold = 0x31,
.tap_duration = 0x10,
.tap_latency = 0x60,
.tap_window = 0xF0,
.tap_axis_control = 0,
.act_axis_control = 0xFF,
.activity_threshold = 5,
.inactivity_threshold = 3,
.inactivity_time = 4,
.free_fall_threshold = 0x7,
.free_fall_time = 0x20,
.data_rate = 0x8,
.data_range = ADXL_FULL_RES,
.ev_type = EV_ABS,
.ev_code_x = ABS_X, /* EV_REL */
.ev_code_y = ABS_Y, /* EV_REL */
.ev_code_z = ABS_Z, /* EV_REL */
.ev_code_tap = {BTN_0, BTN_1, BTN_2}, /* EV_KEY x,y,z */
/*     .ev_code_ff = KEY_F,*/ /* EV_KEY */
/*     .ev_code_act_inactivity = KEY_A,*/ /* EV_KEY */
.power_mode = ADXL_AUTO_SLEEP | ADXL_LINK,
.fifo_mode = ADXL_FIFO_STREAM,
.orientation_enable = 0, /* Disable Orientation Reports */
.deadzone_angle = ADXL_DEADZONE_ANGLE_10p8,
.divisor_length =  ADXL_LP_FILTER_DIVISOR_16,
/* EV_KEY {+Z, +Y, +X, -X, -Y, -Z} */
.ev_codes_orient_3d = {BTN_Z, BTN_Y, BTN_X, BTN_A, BTN_B, BTN_C},
Best Regards,
Mack.
