ADV7181D support input YPrPb(525p), output SDR 8bit 4:2:2 YCrCb ?
Question asked by zbunix on Apr 28, 2014
Latest reply on Apr 30, 2014 by GuenterL
Hi all:
ADV7181D_ADV7181D@_ADV7341-VER.1.0c.txt (found 8bit 422 output)
##CP 525p/625p##
:525p/60Hz YPrPb In 8Bit 422 HS/VS Encoder:
42 05 01 ; PRIM_MODE = 001b COMP
42 06 06 ; VID_STD for 525P 2x1
42 C3 56 ; ADC1 to Ain8, ADC0 to Ain10,
42 C4 B4 ; Enables manual override of mux & ADC2 to Ain6.
42 1D 47 ; Enable 28.63636MHz crystal
42 3A 11 ; Set Latch Clock 01b. Power down ADC3.
42 3B 81 ; Enable Internal Bias
42 3C 3B ; PLL QPUMP to 011b
42 6B 83 ; 422 8bit out
42 C9 00 ; SDR mode
42 73 CF ; Enable Manual Gain and set CH_A gain
42 74 A3 ; Set CH_A and CH_B Gain - 0FAh
42 75 E8 ; Set CH_B and CH_C Gain
42 76 FA ; Set CH_C Gain
42 7B 1C ; Turn off EAV and SAV Codes. Set BLANK_RGB_SEL.
42 85 19 ; Turn off SSPD and force SOY
42 86 0B ; Enable STDI Line Count Mode
42 BF 06 ; Blue Screen Free Run Colour
42 C0 40 ; default color
42 C1 F0 ; default color
42 C2 80 ; Default color
42 C5 01 ;
42 C9 08 ; Enable 8-bit mode using psuedo DDR
42 0E 80 ; ADI recommended sequence
42 52 46 ; ADI recommended sequence
42 54 80 ; ADI Recommended Setting
42 57 01 ; ADI recommended sequence
42 F6 3B ; ADI Recommended Setting
42 0E 00 ; ADI recommended sequence
42 67 2F ; DPP Filters
56 17 02 ; Software Reset
56 00 FC ; Power up all DAcs and PLL
56 01 70 ; SELECT INPUT MODE
56 02 30 ; YPrPb out, SYNC ON
56 30 20 ; ED-HD Nonstandard Timing Mode
56 31 01 ; ED-HD DATA VALID
56 32 02 ; ED-HD MODE REG 3
56 33 2C ; ED-HD MODE REG 4
56 34 48 ; ED-HD MODE REG 5
56 88 00 ; 8 bit input enabled
56 87 20 ; Encoder PAL/NTSC auto-detect enabled
56 8A 0C ; H&v
56 8B 40 ; HS to Pixel shift
End
ADV7181D_Manual_Rev0_12_August_11.pdf(no found 8bit 422 output)
Question1
  ADV7181D support input YPrPb(525p), output single data rate(SDR) 8bit 4:2:2 YCrCb with external syncs(HSync VSync) up to 54MHz(720x480P60) ?
Question2
  Offer the script of ADV718D input YPrPb(525p) output SDR 8bit 4:2:2 YCrCb with external syncs ?
Any suggestion is welcome.
zbunix
