Does ADV7280 support input 525p/60Hz YPrPb, output 8Bit 422 HS/VS SDR mode ?
Question asked by zbunix on Apr 27, 2014
Latest reply on Apr 29, 2014 by DaveD
Hello all,
We have the evaluation board of the ADV7280 connected to:
a YPrPb(525p/60Hz) camera on its Ain1,2,3 input
a BT601 parallel CSI port of Allwinner A10 SOC on its digital camera input
we do test the following two scripts:
1). by modify YPbPr script(##YPrPb AUTODETECT##:YPrPb In Ain1,2,3, YPrPb Out:):
42 0F 00 ; Exit Power Down Mode [ADV7280 Writes Begin]
42 00 0C ; INSEL = YPrPb, Y=Ain1, Pb=Ain2, Pr=Ain3
42 0E 80 ; ADI Required Write
42 04 3D ; 0x04[3].TIME_OE=1 enable hs vs output ----add----
42 6A 03 ; pin_hs=de mode                        ----add----
42 6B 91 ; pin_vs=vsync mode                     ----add----
42 9C 00 ; ADI Required Write
42 9C FF ; ADI Required Write
42 0E 00 ; Enter User Sub Map
42 03 0C ; Enable Pixel & Sync output drivers
42 04 07 ; Power-up INTRQ pad, Enable SFL & VS pin
42 13 00 ; Enable INTRQ output driver
42 1D 40 ; Enable LLC output driver
42 54 C0 ; ADI Required Write
42 80 51 ; ADI Required Write
42 81 51 ; ADI Required Write
42 82 68 ; ADI Required Write [All ADV7280 Writes Finished]
56 00 1C ; Power up Encoder
56 01 00 ; SD only mode
56 80 10 ; SSAF Luma filter enabled, NTSC mode
56 82 C9 ; Step control on, pixel data valid, pedestal on, PrPb SSAF on, YPrPb out.
56 87 20 ; PAL/NTSC autodetect mode enabled
56 88 00 ; 8 bit input enabled [Encoder Writes finished]
====>analog progressive YPbPr display device is black screen. LLC=27Mhz
2). by modify YPbPr script(##YPrPb Interlaced to Progressive##:I2P - YPrPb In Ain1,2,3, 480p EAV/SAV, YPrPb Out:):
42 FD 84 ; Set VPP Map
84 A3 00 ; ADI Required Write
84 5B 00 ; Enable Advanced Timing Mode
84 55 80 ; Enable the Deinterlacer for I2P [All ADV7280 Writes Finished]
56 17 02 ; Reset Encoder
56 00 9C ; Power up DAC's and PLL
56 01 70 ; ED at 54MHz input
56 30 00 ; 525p at 59.94 Hz with external /vsync /hsync Timing
56 31 01 ; Pixel Data Valid [Encoder Writes finished]
====>analog progressive YPbPr display device is black screen. LLC=54Mhz
Question 1
  Does ADV7280 support input 525p/60Hz YPrPb, output 8Bit 422 HS/VS SDR mode(ED-SDR at 54MHz) ?
Question 2
  In ADV7280_CUST-VER.4.5.txt script file, there is no reference script for support input 525p/60Hz YPrPb and output 8Bit 422 HS/VS SDR mode,
  Offer script of the ADV7280 support input 525p/60Hz YPrPb, output 8Bit 422 HS/VS SDR mode(ED-SDR at 54MHz) ?
   I believe there should be some method to config customer to solve this problem, or if there are some other approach.
Thanking you
With best regards and wishes
