AD7731 Communication Issues
Question asked by ISAN on Apr 24, 2014
Latest reply on May 1, 2014 by ChrisD.Rama
Hello all,
I am pulling my hair out. I cannot get any communication from either of the 2 AD7731 ADCs I have.
I am creating a new hardware rev of a  water sanitation system.
The OLD hardware was AD7731 and Atmel128.
New hardware is AD7731 and PIC18f45k22.
I have ported the code from the atmel to the PIC. I am confident in the Code as I can talk to other SPI devices on the board just fine.
As for the AD7731 I cannot get any response from the IC at all. No !RDY pin low, no ability to read the registers, etc.
!RDY stays high at all times.
I received the parts as Analog.com samples.
I have attached schematics for the MCU and the ADC
The !RDY pin NEVER goes LOW. No matter how long I wait.
Here are snippets of my setup and communication code...
// Initialize SPI
// MCU is running @32Mhz, divide  FOSC/64 to run SPI @ 500Khz.
//(Have tried, 2Mhz, 4Mhz, and 8Mhz)
  SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
void Setup_AD7731(void){
    write_register(0x03, 0x13, 0x34);   //Initialize filter register.
// Self calibrate millivolt input  (Electrode Inputs)
// Calibrate Zero point
  write_register(0x02, 0x90, 0xF6); //Self calibrate mV input zero.
  while(AD7731_DR != LOW); //Wait for the ready pin to go low.
  // Set to Full Scale
  write_register(0x02, 0xB0, 0xF6); //Self calibrate mV input full scale.
void write_register(char reg, char msb, char lsb)
  SELECT_AD7731;         //Select the a/d converter.
  SPI1_Write(reg);            //Select the required a/d register.
  SPI1_Write(msb);          //Send msb byte.
  SPI1_Write(lsb);            //Send lsb byte.
  DISABLE_AD7731;       //De-select a/d converter.
This is a direct port from a working system. I am loosing my mind here.
Anyone see what I am doing wrong?
