AD9361 Initialization Problems
Question asked by GiladKR on Apr 22, 2014
Latest reply on May 14, 2014 by DragosB
Branched to a new discussion
I'm using an AD-FMCOMMS3 board connected to a Xilinx KC705 Kintex board running a microblaze processor.
I downloaded the NO-OS drivers and made the needed adaptations (custom SPI and LVDS Interface) and i can transmit and receive RF data.
In the default_init_param i only changed the following lines:
{960000000, 120000000, 120000000, 60000000, 60000000, 60000000},//uint32_trx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
{960000000, 120000000, 120000000, 60000000, 60000000, 60000000},//uint32_ttx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
30000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
30000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
0,
//gc_rx1_mode *** adi,gc-rx1-mode
0,
//gc_rx2_mode *** adi,gc-rx2-mode
I have two main problems:
1.  The configuration frequencies displayed are close but not the same as the requested frequencies.
     For example, when I request a BBPLL frequency of 960,000,000 Hz the driver log displays 990,235,753 Hz as seen below:
ad9361_reset: by SPI
ad9361_rfpll_recalc_rate: Parent Rate 40000000 Hz
ad9361_setup
ad9361_set_dcxo_tune : coarse 8 fine 5920
ad9361_set_trx_clock_chain
ad9361_bbpll_set_rate: Rate 960000000 Hz Parent Rate 40000000 Hz
ad9361_clk_factor_set_rate: Rate 123779469 Hz Parent Rate 990235753 Hz
ad9361_clk_factor_set_rate: Rate 123779469 Hz Parent Rate 123779469 Hz
ad9361_clk_factor_set_rate: Rate 61889734 Hz Parent Rate 123779469 Hz
ad9361_clk_factor_set_rate: Rate 61889734 Hz Parent Rate 61889734 Hz
ad9361_rssi_setup
2.  When transmitting a simple square wave signal (same signal in I and Q) with the same settings stated above to a short (10cm) SMA loopback cable, I receive a very noisy signal in the RX channel regardless of the square wave frequency.
Any help on how to debug these problems will be appreciated.
Gilad
