在BF609平台上,关于blackfin-buildroot-2013R1-RC2的PTP配置问题
Question asked by bander on Apr 21, 2014
Latest reply on Apr 21, 2014 by sonic
在blackfin-buildroot-2013R1-RC2 的linux-menuconfig里面,关于PTP的相关配置为什么找不到[*] STMMAC ieee1588 hw timestamp support选项,如下所示配置(黄色部分在2013R1版本中缺失),编译出uImage并下载到开发板上后,系统启动后,运行hwstamp_ctl 时会提示eth0: No support for HW time stamping,请问,在2013R1版本里面,PTP选项中 ieee1588 hw timestamp 在哪里配置?
To enable hardware timestamp support in bf60x kernel config:
Device Drivers  -->
   [*] Network device support  --->
       [*] Ethernet (10 or 100Mbit) --->
           [*] STMicroelectronics devices
           [*] STMicroelectronics 10/100/1000 Ethernet driver
               [*] STMMAC platform bus support
2013R1版本内核上,运行hwstamp_ctl有问题:
root:/> date
Mon Jan  1 00:03:54 UTC 2007
root:/> date 010101012014
Wed Jan  1 01:01:00 UTC 2014
root:/> date
Wed Jan  1 01:01:04 UTC 2014
root:/> testptp -g
clock time: 0.000000000 or Thu Jan  1 00:00:00 1970
root:/> hwstamp_ctl -i eth0 -r 6 -t 1
stmmaceth stmmaceth.0 eth0: No support for HW time stamping
SIOCSHWTSTAMP failed: Operation not supported
tx_type 1
rx_filter 6
root:/> testptp -s
set time okay
root:/> testptp -g
clock time: 1388538146.060528242 or Wed Jan  1 01:02:26 2014
root:/> testptp -g
root:/> testptp -g
root:/> testptp -g
root:/> ptp4l -i eth0
interface 'eth0' does not support requested timestamping mode.
root:/>
2012R2-RC5版本内核上,运行PTP相关程序均正常:
tx_type 1
rx_filter 6
root:/> ptp4l -i eth0 -P -2 -s -v
ptp4l[173.847]: selected /dev/ptp0 as PTP clock
ptp4l[173.848]: m
ptp4l[173.850]: port 1: INITIALIZING to LISTENING on INITIALIZE
ptp4l[173.851]: port 0: INITIALIZING to LISTENING on INITIALIZE
ptp4l[174.765]: port 1: new foreign master 001e4c.fffe.010002-2
ptp4l[178.764]: selected best master clock 001e4c.fffe.010002
ptp4l[178.765]: foreign master not using PTP timescale
ptp4l[178.766]: running in a temporal vortex
ptp4l[178.766]: port 1: LISTENING to UNCALIBRATED on RS_SLAVE
ptp4l[180.761]: master offset     -26427 s0 adj      +0 path delay        780
ptp4l[181.760]: master offset     -33032 s0 adj      +0 path delay        781
ptp4l[182.765]: master offset     -39695 s0 adj      +0 path delay        784
ptp4l[183.763]: master offset     -46337 s1 adj      +0 path delay        782
