CRC on 1446
Question asked by drugoimir on Apr 18, 2014
Latest reply on May 9, 2014 by drugoimir
i've read that were some issues with the CRC generator on ADAU1442/6,
http://ez.analog.com/message/10660#10660
I've read also the solution proposed by Brett, which consists in clearing the
remaining program ram area and some other tricks to do on the compiled
hex file generated (i' did read it, but not in deep).
Since that discussion was 4 years old and thinking that ADI fixed this into the
last SigmaStudio, i tried "the easy way" using directly the file generated
by sigmastudio, but i see that some weird things are still present:
This is a program compiled without CRC check
void default_download_IC_1() {
    SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, REG_START_PULSE_SELECT_IC_1_ADDR, REG_START_PULSE_SELECT_IC_1_BYTE, R0_START_PULSE_SELECT_IC_1_Default );
    SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, REG_CORE_RUN_BIT_IC_1_ADDR, REG_CORE_RUN_BIT_IC_1_BYTE, R1_CORE_RUN_BIT_IC_1_Default );
    SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, PROGRAM_ADDR_IC_1, PROGRAM_SIZE_IC_1, Program_Data_IC_1 );
    SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, REG_SERIALINPUT0_DEFAULT_IC_1_ADDR , R3_SERIAL_INPUT_MODES_IC_1_SIZE, R3_SERIAL_INPUT_MODES_IC_1_Default );
This is what i get when i turn on the CRC error check
    SIGMA_WRITE_REGISTER_BLOCK( DEVICE_ADDR_IC_1, REG_SERIALINPUT0_DEFAULT_IC_1_ADDR , R10_SERIAL_INPUT_MODES_IC_1_SIZE, R10_SERIAL_INPUT_MODES_IC_1_Default );
In this latter case, it seems that the program memory is being loaded 8 times (?) and  also many registers are not defined.
Here are some, but there are many more:
R4_SERIAL_OUTPUT_MODES_IC_1_SIZE
So, what i've to do?
I've to "hack" the compiled hex as per Brett's workaround ?
May i apply the workaround on the "xxx.h, xx_param.h, xx_REG.h" files ?
I'm using those for device control and upload.
I'm about finishing this project and i'm missing just this feature, i cannot terminate it without.
Thanks for any advice.
Tom
