Adxl345 linux driver freezes, [raspberry pi i2c]
Question asked by jahoo11 on Apr 17, 2014
Latest reply on May 20, 2014 by larsc
I did everything like Peetah in this topic :http://ez.analog.com/message/130856?tstart=0#130856 (thanks men)
but there is a problem.
Sudo evtest /dev/input/event0 returns proper values but in less than a minute it freeze and doesn't returns anything. If i try to run evtest again it returns the last value from previous test. Do you have any ideas about possible causes?
ps. Is it possible to connect more than one adxl345 on spi to raspberry with this driver?
ps2. On low ODR (0.39hz - rate set to 2) it seems to work fine for couple hours, but i need much higher ODR (3200hz)...
How to change g- range of this accelerometer?
