AD9361 BBPLL fails to lock on prototype
Question asked by daniel.meinzer on Apr 16, 2014
Latest reply on Jul 29, 2014 by mhennerich
Greetings, I have the AD9361 on a custom board with an FPGA.  I also have the Xilinx KC705 FPGA evaluation board and a AD-FMCOMMS2-EBZ.
I am unable to get the AD9361 on my custom board to successful get a BBPLL lock.  However, it works fine with the evaluation board.  I have attached my debug messages and main.c configuration.
I am running your No-OS driver on a desktop computer in order to configure the AD9361 over SPI.  The driver has no modifications other than some extra debug messages and the necessary modifications to the SPI interface for my platform.  I am running the exact same executable to configure each testbed (custom board, and eval board).  And I have verified that up until calibration, all register reads and writes from and to the device are identical.
I am using VDD_INTERFACE = 1.8V, VDD_GPO = 3.15V, and providing 1.3V to the analog supplies.  I have monitored these during my configuration procedure and don't see any noticeable integrity issues with the power supplies.
Also of note, is I am using an external reference with both setups, at 40 MHz.  So the crystal is removed from the evaluation board, and a 0.1uF capacitor is placed to connect to REF_CLK SMA.  My custom board is setup exactly the same.
Any idea why this would work on the eval board and not my custom implementation?
What is the BBPLL sensitive to?
What pins power the BBPLL and it's calibration?
Is there anything else I can monitor to determine why it's not calibrating?
AD9361_InitParam default_init_param = {
  /* Reference Clock */
  40000000UL, //reference_clk_rate
  /* Base Configuration */
  1, //two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
  1, //frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
  0, //tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
  0, //tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
  0, //tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
  0, //rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
  0, //rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
  0, //tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
  0, //external_rx_lo_enable *** adi,external-rx-lo-enable
  0, //external_tx_lo_enable *** adi,external-tx-lo-enable
  5, //dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
  6, //dc_offset_attenuation_high_range *** adi,dc-offset-tracking-update-event-mask
  5, //dc_offset_attenuation_low_range *** adi,dc-offset-tracking-update-event-mask
  0x28, //dc_offset_count_high_range *** adi,dc-offset-tracking-update-event-mask
  0x32, //dc_offset_count_low_range *** adi,dc-offset-tracking-update-event-mask
  0, //tdd_use_fdd_vco_tables_enable *** adi,tdd-use-fdd-vco-tables-enable
  0, //split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
  /* ENSM Control */
  0, //ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
  0, //ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
  /* LO Control */
  2400000000UL, //rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
  2400000000UL, //tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
  /* Rate & BW Control */
  // BBPLL_FREQ, ADC_FREQ, R2_FREQ, R1_FREQ, CLKRF_FREQ, RX_SAMPL_FREQ,
  {983040000, 491520000, 491520000, 245760000, 122880000, 61440000},//uint32_t rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
  {983040000, 491520000, 491520000, 245760000, 122880000, 61440000},//uint32_t tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
  18000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
  18000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
  /* RF Port Control */
  0, //rx_rf_port_input_select *** adi,rx-rf-port-input-select
  0, //tx_rf_port_input_select *** adi,tx-rf-port-input-select
  /* TX Attenuation Control */
  20000, //tx_attenuation_mdB *** adi,tx-attenuation-mdB
  0, //update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
  /* Reference Clock Control */
  1, //xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
  {8, 5920}, //dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
  0, //clk_output_mode_select *** adi,clk-output-mode-select
  /* Gain Control */
  2, //gc_rx1_mode *** adi,gc-rx1-mode
  2, //gc_rx2_mode *** adi,gc-rx2-mode
  58, //gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
  4, //gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
  47, //gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
  8192, //gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
  0, //gc_dig_gain_enable *** adi,gc-dig-gain-enable
  800, //gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
  704, //gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
  24, //gc_low_power_thresh *** adi,gc-low-power-thresh
  15, //gc_max_dig_gain *** adi,gc-max-dig-gain
  /* Gain MGC Control */
  2, //mgc_dec_gain_step *** adi,mgc-dec-gain-step
  2, //mgc_inc_gain_step *** adi,mgc-inc-gain-step
  0, //mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
  0, //mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
  0, //mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
  /* Gain AGC Control */
  10, //agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
  2, //agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
  0, //agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
  10, //agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
  4, //agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
  3, //agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
  1000, // agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
  0, //agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
  0, //agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
  10, //agc_inner_thresh_high *** adi,agc-inner-thresh-high
  1, //agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
  12, //agc_inner_thresh_low *** adi,agc-inner-thresh-low
  1, //agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
  10, //agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
  2, //agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
  10, //agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
  5, //agc_outer_thresh_high *** adi,agc-outer-thresh-high
  2, //agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
  18, //agc_outer_thresh_low *** adi,agc-outer-thresh-low
  2, //agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
  1, //agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
  0, //agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
  /* Fast AGC */
  64, //fagc_dec_pow_measuremnt_duration ***  adi,fagc-dec-pow-measurement-duration
  260, //fagc_state_wait_time_ns ***  adi,fagc-state-wait-time-ns
  /* Fast AGC - Low Power */
  0, //fagc_allow_agc_gain_increase ***  adi,fagc-allow-agc-gain-increase-enable
  5, //fagc_lp_thresh_increment_time ***  adi,fagc-lp-thresh-increment-time
  1, //fagc_lp_thresh_increment_steps ***  adi,fagc-lp-thresh-increment-steps
  /* Fast AGC - Lock Level */
  10, //fagc_lock_level ***  adi,fagc-lock-level */
  1, //fagc_lock_level_lmt_gain_increase_en ***  adi,fagc-lock-level-lmt-gain-increase-enable
  5, //fagc_lock_level_gain_increase_upper_limit ***  adi,fagc-lock-level-gain-increase-upper-limit
  /* Fast AGC - Peak Detectors and Final Settling */
  1, //fagc_lpf_final_settling_steps ***  adi,fagc-lpf-final-settling-steps
  1, //fagc_lmt_final_settling_steps ***  adi,fagc-lmt-final-settling-steps
  3, //fagc_final_overrange_count ***  adi,fagc-final-overrange-count
  /* Fast AGC - Final Power Test */
  0, //fagc_gain_increase_after_gain_lock_en ***  adi,fagc-gain-increase-after-gain-lock-enable
  /* Fast AGC - Unlocking the Gain */
  /* 0 = MAX Gain, 1 = Optimized Gain, 2 = Set Gain */
  0, //fagc_gain_index_type_after_exit_rx_mode ***  adi,fagc-gain-index-type-after-exit-rx-mode
  1, //fagc_use_last_lock_level_for_set_gain_en ***  adi,fagc-use-last-lock-level-for-set-gain-enable
  1, //fagc_rst_gla_stronger_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
  5, //fagc_optimized_gain_offset ***  adi,fagc-optimized-gain-offset
  10, //fagc_rst_gla_stronger_sig_thresh_above_ll ***  adi,fagc-rst-gla-stronger-sig-thresh-above-ll
  1, //fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
  1, //fagc_rst_gla_engergy_lost_goto_optim_gain_en ***  adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
  10, //fagc_rst_gla_engergy_lost_sig_thresh_below_ll ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
  8, //fagc_energy_lost_stronger_sig_gain_lock_exit_cnt ***  adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
  1, //fagc_rst_gla_large_adc_overload_en ***  adi,fagc-rst-gla-large-adc-overload-enable
  1, //fagc_rst_gla_large_lmt_overload_en ***  adi,fagc-rst-gla-large-lmt-overload-enable
  0, //fagc_rst_gla_en_agc_pulled_high_en ***  adi,fagc-rst-gla-en-agc-pulled-high-enable
  0, //fagc_rst_gla_if_en_agc_pulled_high_mode ***  adi,fagc-rst-gla-if-en-agc-pulled-high-mode
  64, //fagc_power_measurement_duration_in_state5 ***  adi,fagc-power-measurement-duration-in-state5
  /* RSSI Control */
  1, //rssi_delay *** adi,rssi-delay
  1000, //rssi_duration *** adi,rssi-duration
  3, //rssi_restart_mode *** adi,rssi-restart-mode
  0, //rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
  1, //rssi_wait *** adi,rssi-wait
  /* Aux ADC Control */
  256, //aux_adc_decimation *** adi,aux-adc-decimation
  40000000UL, //aux_adc_rate *** adi,aux-adc-rate
  /* AuxDAC Control */
  1, //aux_dac_manual_mode_enable ***  adi,aux-dac-manual-mode-enable
  0, //aux_dac1_default_value_mV ***  adi,aux-dac1-default-value-mV
  0, //aux_dac1_active_in_rx_enable ***  adi,aux-dac1-active-in-rx-enable
  0, //aux_dac1_active_in_tx_enable ***  adi,aux-dac1-active-in-tx-enable
  0, //aux_dac1_active_in_alert_enable ***  adi,aux-dac1-active-in-alert-enable
  0, //aux_dac1_rx_delay_us ***  adi,aux-dac1-rx-delay-us
  0, //aux_dac1_tx_delay_us ***  adi,aux-dac1-tx-delay-us
  0, //aux_dac2_default_value_mV ***  adi,aux-dac2-default-value-mV
  0, //aux_dac2_active_in_rx_enable ***  adi,aux-dac2-active-in-rx-enable
  0, //aux_dac2_active_in_tx_enable ***  adi,aux-dac2-active-in-tx-enable
  0, //aux_dac2_active_in_alert_enable ***  adi,aux-dac2-active-in-alert-enable
  0, //aux_dac2_rx_delay_us ***  adi,aux-dac2-rx-delay-us
  0, //aux_dac2_tx_delay_us ***  adi,aux-dac2-tx-delay-us
  /* Temperature Sensor Control */
  256, //temp_sense_decimation *** adi,temp-sense-decimation
  1000, //temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
  0xCE, //temp_sense_offset_signed *** adi,temp-sense-offset-signed
  1, //temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
  /* Control Out Setup */
  0xFF, //ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
  0, //ctrl_outs_index *** adi,ctrl-outs-index
  /* External LNA Control */
  0, //elna_settling_delay_ns *** adi,elna-settling-delay-ns
  0, //elna_gain_mdB *** adi,elna-gain-mdB
  0, //elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
  0, //elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
  0, //elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
  /* Digital Interface Control */
  1, //pp_tx_swap_enable *** adi,pp-tx-swap-enable
  1, //pp_rx_swap_enable *** adi,pp-rx-swap-enable
  0, //tx_channel_swap_enable *** adi,tx-channel-swap-enable
  0, //rx_channel_swap_enable *** adi,rx-channel-swap-enable
  1, //rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
  1, //two_t_two_r_timing_enable *** adi,2t2r-timing-enable
  0, //invert_data_bus_enable *** adi,invert-data-bus-enable
  0, //invert_data_clk_enable *** adi,invert-data-clk-enable
  0, //fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
  0, //invert_rx_frame_enable *** adi,invert-rx-frame-enable
  0, //fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
  0, //swap_ports_enable *** adi,swap-ports-enable
  0, //single_data_rate_enable *** adi,single-data-rate-enable
  1, //lvds_mode_enable *** adi,lvds-mode-enable
  0, //half_duplex_mode_enable *** adi,half-duplex-mode-enable
  0, //single_port_mode_enable *** adi,single-port-mode-enable
  0, //full_port_enable *** adi,full-port-enable
  0, //full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
  0, //delay_rx_data *** adi,delay-rx-data
  0, //rx_data_clock_delay *** adi,rx-data-clock-delay
  0, //rx_data_delay *** adi,rx-data-delay
  0, //tx_fb_clock_delay *** adi,tx-fb-clock-delay
  4, //tx_data_delay *** adi,tx-data-delay
  150, //lvds_bias_mV *** adi,lvds-bias-mV
  1, //lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
