matteit
ADAS1000 *drdy signal
Discussion created by matteit on Apr 14, 2014
Latest reply on May 2, 2014 by Padraic
Using data sheet example 6, Master/Slave 2khz frame rate setup, the *drdy signal should clear after reading one frame.  However, it does not clear unless I read two full frames of data every time.  Note, the frame header does inidicate that the data was not ready.  Is there any errata on *drdy?
