i2c Scl clock is not generated in ADuC7060?
Question asked by Karthickph on Apr 11, 2014
Latest reply on Apr 15, 2014 by Karthickph
Hi there, I'm using ADuC7060 microconverter for our product development.  Software needs to communicate with tmp432 (slave device) and ADuC7060 (master) board through i2c protocol.   I developed the code and flashed it.  But it seems not working straightway.  Initially I thought of checking scl line to confirm that generate 100.3KHz clock signal (please note that 4.7 Kohm - 10Kohm resistance tried as pull up resistor which connects to 3.3V).  Still the scl clock was not generated.  Please see the firmware configuration settings given below.  Am I missing any other configuration settings or need to do any other hardware changes.  (I'm using ADuC7060 eval board Rev1 for this purpose).
POWKEY1 = 0x1;
POWCON0 = 0x78;     // Set core to max CPU speed of 10.24Mhz
POWKEY2 = 0xF4;
// Configure P0.1 and P0.3 for I2C mode. Configure P1.0 and P1.1 for UART mode.
GP0CON0 = BIT4 + BIT12; // Select SPI/I2C alternative function for P0.1 & P0.3
GP0KEY1 = 0x7;     // Write to GP0KEY1
GP0CON1 = BIT1;     // Select I2C functionality for P0.1 & P0.3
GP0KEY2 = 0x13;     // Write to GP0KEY2
GP1CON = BIT0 + BIT4;  // Select UART functionality for P1.0/P1.1
// Enable I2C Master mode, baud rate and interrupt sources
I2CMCON = BIT0 + BIT4  // Enable I2C Master + Enable Rx interrupt
   + BIT5 + BIT7 + BIT8; // Enable Tx interrupt + Enable transmission complete interrupt
I2CDIV  = 0x3131;    // Select 100.3kHz clock rate
IRQEN = BIT15 + BIT11; // Enable I2C Master and UART interrupts
Thank you,
Karthick
