c++ template instantiation & linker
Question asked by AndreyZ on Apr 9, 2014
Latest reply on Oct 12, 2014 by AndreyZ
Hi guys, i'm used to try using templates in my project until i started to get the messages from the linker about multiply defined symbols
I found that compiler includes cpp files into other files by default.
but i want to use explicit instatiation.
LexicalMaster.hxx:
template<typename StringType>
class LexicalMaster
     static const std::map<int,StringType> &_member;
     static const std::map<int,StringType> &Init()
          static std::map<int,StringType> _tmp;
          _tmp.insert(std::map<int,StringType>::value_type(1,"example1"));
          _tmp.insert(std::map<int,StringType>::value_type(2,"example2"));
          return _tmp;
LexicalMaster.cxx:
const std::map<int,StringType> &LexicalMaster<StringType>::_member = LexicalMaster<StringType>::Init();
Ok, the compiler switch "-no-implicit-inclusion" prevents inclusion of the LexicalMaster.cxx to other files, but now i can't get any effect using any following expressions:
LexicalMaster.cxx:
template class LexicalMaster<std::string>; //ISO/IEC 14882:2003 style
or
#pragma instantiate class LexicalMaster<std::string> //visualdsp style
>process build datetime
.\Source\LexicalMaster.cxx
Linking...
[Error li1021]  The following symbols referenced in processor 'p0' could not be resolved:
'std::map<int,StringType> &LexicalMaster<T1>::_member [with T1=string] [_Trim__29LexicalMaster__tm__9_c6stringSFRZ2ZPCZ1Z_RZ2Z]' referenced from '.\Obj\...\SomeFile.doj'
also a found that anyting typed at these strings affects nothing, even if it's a garbage:
tempsdsdlate class LexicalMaster<std::string::value_type,std::string>;            //wtf?
#pragmswa3da instantiate LexicalMaster<std::string::value_type,std::string>   //wtf?
Linking...
Other.cxx just uses LexicalMaster<std::string> but i got the linker error about unresolved symbol
ps: i edited linker error to contain "std::map<int,StringType>" just because i dont whant to care about std::map full name in this post
please help to understand whats going on with this compiler
best regards,
Andrey Z
