AVNET ZEDBOARD AD9467-FMC
Question asked by Stanislav on Apr 4, 2014
Latest reply on Apr 9, 2014 by umaair_653
Hi
I am read http://wiki.analog.com/resources/tools-software/linux-drivers/iio-adc/axi-adc-hdl.
I use kernel xcomm_zynq_3_10 https://github.com/analogdevicesinc/linux/tree/xcomm_zynq_3_10.
In configuration kernel I don't find:
Linux Kernel Configuration
Device Drivers  --->
<*>     Industrial I/O support --->
--- Industrial I/O support
-*-   Enable ring buffer support within IIO
-*-     Industrial I/O lock free software ring
-*-   Enable triggered sampling support
*** Analog to digital converters ***
[--snip--]
<*>   Analog Devices AD9467 AD9643 High-Speed AXI ADC driver
[--snip--]
Then when I load kernel:
Booting Linux on physical CPU 0x0
Linux version 3.10.0-xilinx-gf416e32 (root@ubuntu) (gcc version 4.7.3 (Sourcery CodeBench Lite 2013.05-39) ) #5 SMP PREEMPT Fri Apr 4 12:40:24 MSK 2014
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Xilinx Zynq Platform, model: Xilinx Zynq
cma: CMA: reserved 16 MiB at 1e800000
Memory policy: ECC disabled, Data cache writealloc
On node 0 totalpages: 131072
free_area_init_node: node 0, pgdat c05c0f80, node_mem_map c05f7000
  Normal zone: 1024 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 131072 pages, LIFO batch:31
PERCPU: Embedded 8 pages/cpu @c09fe000 s8256 r8192 d16320 u32768
pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw rootwait
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 497140k/497140k available, 27148k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc055ec50   (5468 kB)
      .init : 0xc055f000 - 0xc058b040   ( 177 kB)
      .data : 0xc058c000 - 0xc05c9478   ( 246 kB)
       .bss : 0xc05c9478 - 0xc05f64b4   ( 181 kB)
Preemptible hierarchical RCU implementation.
          Dump stacks of tasks blocking RCU-preempt GP.
          RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:16 nr_irqs:16 16
ps7-slcr mapped to e0802000
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207ms
ps7-ttc #0 at e0804000, irq=43
Console: colour dummy device 80x30
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0xc03e3a98 - 0xc03e3af0
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
xgpiops e000a000.ps7-gpio: gpio at 0xe000a000 mapped to 0xe080c000
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Switching to clocksource ttc_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
jffs2: version 2.2. (NAND) (SUMMARY)  \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc.
msgmni has been set to 1002
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-267056
dma-pl330 f8003000.ps7-dma:           DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.ps7-dev-cfg: ioremap f8007000 to e0862000 with size 100
brd: module loaded
loop: module loaded
xilinx_spi 42000000.spi: master is unqueued, this is deprecated
xilinx_spi 42000000.spi: at 0x42000000 mapped to 0xe0880000, irq=90
------------[ cut here ]------------
WARNING: at fs/sysfs/dir.c:530 sysfs_add_one+0x78/0x98()
sysfs: cannot create duplicate filename '/class/spi_master/spi0'
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0-xilinx-gf416e32 #5
[<c0014560>] (unwind_backtrace+0x0/0x11c) from [<c0011664>] (show_stack+0x10/0x14)
[<c0011664>] (show_stack+0x10/0x14) from [<c0020614>] (warn_slowpath_common+0x4c/0x6c)
[<c0020614>] (warn_slowpath_common+0x4c/0x6c) from [<c00206b4>] (warn_slowpath_fmt+0x2c/0x3c)
[<c00206b4>] (warn_slowpath_fmt+0x2c/0x3c) from [<c00f5444>] (sysfs_add_one+0x78/0x98)
[<c00f5444>] (sysfs_add_one+0x78/0x98) from [<c00f5fe0>] (sysfs_do_create_link_sd+0xfc/0x1d4)
[<c00f5fe0>] (sysfs_do_create_link_sd+0xfc/0x1d4) from [<c02177fc>] (device_add+0x23c/0x5bc)
[<c02177fc>] (device_add+0x23c/0x5bc) from [<c025dce8>] (spi_register_master+0x180/0x5f8)
[<c025dce8>] (spi_register_master+0x180/0x5f8) from [<c0260d58>] (xqspips_probe+0x2f8/0x4f4)
[<c0260d58>] (xqspips_probe+0x2f8/0x4f4) from [<c021b27c>] (platform_drv_probe+0x14/0x18)
[<c021b27c>] (platform_drv_probe+0x14/0x18) from [<c0219f9c>] (driver_probe_device+0x118/0x32c)
[<c0219f9c>] (driver_probe_device+0x118/0x32c) from [<c021a218>] (__driver_attach+0x68/0x8c)
[<c021a218>] (__driver_attach+0x68/0x8c) from [<c02184cc>] (bus_for_each_dev+0x50/0x88)
[<c02184cc>] (bus_for_each_dev+0x50/0x88) from [<c02195b0>] (bus_add_driver+0xec/0x244)
[<c02195b0>] (bus_add_driver+0xec/0x244) from [<c021a70c>] (driver_register+0x9c/0x12c)
[<c021a70c>] (driver_register+0x9c/0x12c) from [<c000863c>] (do_one_initcall+0xcc/0x180)
[<c000863c>] (do_one_initcall+0xcc/0x180) from [<c055f908>] (kernel_init_freeable+0xfc/0x1c4)
[<c055f908>] (kernel_init_freeable+0xfc/0x1c4) from [<c03d8854>] (kernel_init+0x8/0xe4)
[<c03d8854>] (kernel_init+0x8/0xe4) from [<c000e698>] (ret_from_fork+0x14/0x3c)
---[ end trace c5f8f2d28c10b577 ]---
xqspips e000d000.ps7-qspi: spi_register_master failed
xqspips: probe of e000d000.ps7-qspi failed with error -17
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
libphy: XEMACPS mii bus: probed
xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
xi2cps e0004000.ps7-i2c: 400 kHz mmio e0004000 irq 57
xadcps f8007100.ps7-xadc: enabled:          yes          reference:          external
zynq-edac f8006000.ps7-ddrc: ecc not enabled
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
cf_axi_adc 79000000.axi-adc-1c: Device Tree Probing 'axi-adc-1c'
cf_axi_adc 79000000.axi-adc-1c: could not find spi node
TCP: cubic registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Registering SWP/SWPB emulation handler
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Waiting for root device /dev/mmcblk0p2...
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SD04G 3.70 GiB
mmcblk0: p1 p2
EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 176K (c055f000 - c058b000)
udevd[622]: starting version 175
EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
NET: Registered protocol family 10
xemacps e000b000.ps7-ethernet: Set clk to 124999998 Hz
xemacps e000b000.ps7-ethernet: link up (1000/FULL)
Catalog /sys/bus/iio/devices/  is empty!!!
The main questions is:
1. What kernel version correctly for my platform(ZYNQ-7000 EPP 7Z020 ZedBoard) ?
2. How can I correctly edit devicetree.dts
