a couple of question for AD8260
Question asked by Kaos on Apr 4, 2014
Latest reply on Apr 13, 2014 by Kaos
Dear Sir/Madam,
I have a couple of question for your AD8260.
1)
I will just use only the high current driver part.
Not use VGA/PreAMP and VMID buffer parts.
If so, how should I connect the NOT USING PIN,  GND or OPEN or Pull-up high level?
And please give me the good comment for such way? Can I use only high current driver part?
2)
Can I use by 5V single ended power supply for the high currnet part?
If so yes, what is the output current? How should think it?
On your data sheet. I can see RLOAD = 1 Ω, VIN = ±0.5 V +/-310mA only ,I cannot find the case of single end input.
Our application is radio device.
AD8260 get the diff-signal 1Vp-p from AD9762 DAC and take the signal to next LPF for transmit by antenna.
AD9762 get the 3MHz FSK signal from front device. So I use the signal 1MHz to 4MHz on AD8260.
If you have an another good device for this case, please recommend it to me?
I need around 0.3W the outout power from driver.
Thanks Kaos
