BF506F EZ-Kit Lite Sample_ADC_ACM_Control - low sampling rate?
Question asked by MBHeitec on Apr 4, 2014
Latest reply on May 5, 2014 by VineethaThomas
I'm new to DSP-programming and tried to adapt the Sample_ADC_ACM_Control example, that comes with the VisualDSP++, to fit my requirements. I need an ADC samling rate of about 1MHz (1MS/s) and 3 channels. The example program works fine now and i understand the code.
The problem is that i can not sample very fast. The fastest possible sampling rate at the moment is about 1kHz. Where is the problem? If I shorten the event time to get higher sampling rate, the buffer will not be filled anymore and the program is waiting to receive samples. Via pll I have set a CCLK frequency of 400MHz and a SCLK frequency of 80MHz. So why do i can not sample any faster?
The fastest possible working conditions are the following:
/*=============  D E F I N E S  =============*/
/* ACM Device number to control ADC*/
#define     ADC_TEST_ACM_DEV_NUM            0
/* SPORT Device number connected to ADC */
#define     ADC_TEST_SPORT_DEV_NUM          1
/* SPORT Device DMA Bus width (16 bits) */
#define     ADC_TEST_SPORT_DMA_BUS_WIDTH    2
/* ADC Clock (ACLK) frequency in Hertz */
#define     ADC_TEST_ACLK_FREQ              40000000u
/* Number of ACM events per trigger (Max value = 16) */
#define     ADC_TEST_NUM_ACM_EVENTS         3
/* Time get the first ADC Sample (ACM First event time) */
#define     ADC_TEST_ACM_EVENT_BASE_TIME    0
/* Interval between ADC samples (Interval between ACM events) */
#define     ADC_TEST_ACM_EVENT_INTERVAL     8000
/* GP Timer to trigger ACM */
#define     ADC_TEST_ACM_TGR_GP_TIMER       ADI_TMR_GP_TIMER_7
/* ACM Trigger Timer Period */
#define     ADC_TEST_ACM_TGR_TMR_PERIOD     (ADC_TEST_ACM_EVENT_INTERVAL * ADC_TEST_NUM_ACM_EVENTS)
/* ACM Trigger Timer Width */
#define     ADC_TEST_ACM_TGR_TMR_WIDTH      8000
/* ADC Serial data mode */
#define     ACM_TEST_SERIAL_DATA_MODE       ADI_BF506FADC1_DATA_DOUT_A_ONLY
/* Number of Samples to receive */
#define     ADC_TEST_NUM_SAMPLES            3
in the main function i changed the event parameter array:
/* Populate ACM Event Parameter array */
    for (i = 0;
         i < ADC_TEST_NUM_ACM_EVENTS;
         i++)
        /* Event Number */
        aoAcmEventParams[i].nEventNumber = i;
        /* Enable event */
        aoAcmEventParams[i].bEnable = true;
        /* ADC Channel select - between 0 and 2 */
        aoAcmEventParams[i].nAdcCannelSelect = (i % 3);
        /* ADC Range select - 0 for even numbered events, 1 for odd numbered events */
        aoAcmEventParams[i].nRange = 0;/*(i % 2);*/
        /* ADC Logic select - 0 for even numbered events, 1 for odd numbered events */
        aoAcmEventParams[i].nLogic = 1;/*(i % 2);*/
        /* ADC Event Time */
        aoAcmEventParams[i].nTime = ADC_TEST_ACM_EVENT_BASE_TIME + (i * ADC_TEST_ACM_EVENT_INTERVAL);
For the complete code, check the attached file please.
